Cold Dark Shadow
- Mar 24, 2003
UPDATE 12.16.08
ok decided that instead of just a new motherboard, a proc. might not be a bad idea either if a good deal is floating around. If you got just motherboard suggestions ill listen to those too
Id like to reuse the RAM and everything
AMD/intel doesnt matter anymore
wont OC
single card support is just fine
price range under $300 for both would be nice, even cheaper would be great
around $100 for just the motherboard
right now im using a GIGABYTE GA-MA69GM-S2H 690G HDMI (left froma mATX build) but its a mATX and id like to go to a ATX
Other specs:
AMD x2 5000+BE
eVGA 9800GTX
4GB 800 OCZ Reaper
Corsair 520HX
CMStacker case (plan to go to a antec 900)
wont OC
Other specs:
AMD x2 5000+BE
eVGA 9800GTX
4GB 800 OCZ Reaper
Corsair 520HX
