Need motherboard recommendation
ak47is1337
My P5E motherboard just recently died with a CMOS Checksum Error plus an overvoltage on the USB port error. Great! This board has sucked at overclocking from the start, and it has really been a pain trying to get it stable. Anyway, I'll be RMA'ing ASAP and just selling the return on eBay or on [H].
I was wondering if anybody had a good recommendation for overclocking motherboards. My budget is about $200, and X38 or P35 boards are good to go. I don't mind if it is used or open box.
I have previously used an IP35 Pro and was highly impressed with how gracious it was to overclocking. I know that board is now legendary, but is the IX38 QuadGT just as good/better? It's slightly out of my price range, but I might be able to make an exception if it's really good.
The Gigabyte EX38/X38-DQ6 has also caught my attention because it has won numerous awards. I don't know all that much about this board, but it looks like a solid, reliable clocker.
I am also considering a whole lot of DFI boards. I don't understand DFI's different boards variants and what UT/LT means when it comes to performance, and whether or not they are worth the money. I had an old DFI Ultra-D back in the day, and while it was a great clocker, it was not reliable worth sh**. I have also heard horror stories from the P965 series boards they made. Are they worth checking out for a P35/X38 chipset?
Finally, I have been looking at a few ASUS Maximus boards. I am a bit weary though, because they are extremely expensive and based on the P5E PCB that failed me.
Please keep in mind that I plan on sticking to my DDR2 Tracers and while I will use my E3220 (Q6600 G0) for a little while, I will upgrade to a Q9450 eventually, so quad clocking is what matters to me.
Any help is appreciated guys, thanks.
afaik the IX38 QuadGT is very similar to the IP35 Pro.
Of course the BIOS isn't as mature but then it's a far newer mobo.
Highest fsb screenie that I have seen on it was 582fsb.
From what I have read I would take it over the Gigabytes & at least in the UK it's not far off the P5E in pricing & again cheaper than the Gigabyte DQ6.
the IX38 wasn't based off the IP35's PCB was it? I know they're very similar, but that's actually kind of why I was looking at it, because the IP35 Pro would put up with anything you threw at it.
there's certainly a lot of IP35 Pro DNA in the IX38 QuadGT (& there was a lot of AB9 QuadGT DNA in the IP35 Pro).
The IX38 has 5 phase digital PWM though (less Vdroop but runs hotter although it's specified to) as well as the obvious PCI-E slot & chipset differences.
I have a Maximus and have had no problems whatsoever with mine...FWIW. If you're leary of the P5E, I probably wouldn't go with the Maximus since it's very similar.
I'd probably go with the IX38. For one thing, it can't be all that bad, and most CPU's will hit the limit before 500+ FSB comes into play. I was going to get the IX38, but got tired of waiting for it to hit the market.
well the IX38 is looking quite attractive, but what about DFI? is the lanparty UT P35-TR2 any good?
Yes, it is pretty good, however it is also priced rather high compared to other P35 boards. The DFI DK P35 version is somewhat cheaper. I'd personally get that. Not quite as good, but 98% of the performance for $40 cheaper.
i think this is just going to require long hours of ebaying lolz. so would you say the gigabyte X38-DQ6 is worth pursuing, or is the abit and dfi that much better?
i think this is just going to require long hours of ebaying lolz. so would you say the gigabyte X38-DQ6 is worth pursuing? i got an offer for 190, but should i just for a dark instead?
I own a DFI LanParty DK P35-T2RS and couldn't be any happier with the board. Stable as crap and I have my E3110 at 4.0ghz oc with only .1v increase. YMMV though.
from what I understand the IX38 is a better mobo than the X38-DQ6.
You liked the IP35 Pro & it's $135 after rebate at Newegg.
If you don't need the extra lanes PCI-E 2.0 of X38 what's wrong with going back to that?
Or there is a new XE version coming with official 1600fsb support.
IP35 Pro had some problems with vDroop and it didn't hit particularly high FSB's with my luck, plus it's kind of old so I'm not sure how long they're going to keep making BIOS updates for it.
The mobo is capable of over 500fsb with duals & middle 400s with quads (like most P35s).
More often the CPU is the cause of not hitting high fsb not the mobo.
abit have a good track record of continuing BIOS support for mobos as long as practicable.
Remember that in under a year new Intel CPUs change sockets so no 775 mobo will be getting BIOS support for new CPUs after that as they won't fit ;).
