Hey Guys -
I recently recently received the following parts, and I'm in the process of building a "Monster" as my Buddy referred to it:
Intel Q9650 45nm
EVGA GTX 280 Superclocked
WD VeliciRapror 300GB
Seagate 7200.11 1TB
Vista Home Prem 64 (was FREE)
I don't want to double post, so I am guessing I'll just make one post here and hope it gets the job done. I need a good solid recommendation on a board supporting DDR3. Can any one enlighten me on the different chip sets (P35/X48/790i etc...)? I guess what I'm getting at, is one better than the other? If so, why - be it personal preference, stability, ease of use, problems with one as opposed to another? As of now, I doubt I'll be OC, but I'd like to have the options there for future use. I'm more interested in initial set-up stability right now, and I'll start to tweak things in the weeks thereafter. Initially, I don't "need" SLI, but would like to have it there for the future if and when I need it. I have heard that if you plan on only using one video card for now, that the X48 chip set is a better buy. Can any one confirm/deny this?
Also, as far as DDR3 goes, I have heard a number of different things. Do you HAVE to use the 1:1 ratio - i.e. b/c my CPU is 1333MHz FSB, does the RAM HAVE to match? I have heard yes and no respectively. Can I use any speed? I've also heard using the 1:1 ratio is gimped as well. Can any one confirm/deny this? I have never really one to OC RAM in the past though, but want solid stability.
THX in advance.
Intel Q9650 45nm
Seagate 7200.11 1TB
THX in advance.
