Need Mobo and Processor, but what?
h0mez
Ok, so I had an older P4 with some RDRAM in it which I sold on ebay for 240$ :) . Now I have a gig of DDR400, and an AGP 5700. I have currently about 275~ to spend on a new bored and cpu and video card/DDR2. Obviously its going to be hard to find and AGP bored with DDR400 with a decent processor on it. I did find on the Egg that I can get...
http://www.newegg.com/Product/Product.asp?item=N82E16813131569
http://www.newegg.com/Product/Product.asp?item=N82E16819103622
http://www.newegg.com/Product/Product.asp?item=N82E16814131028
Comes out to 256$ then I get another 20$ rebate, and I can still use my memory. I just really play WoW, and then do basic school stuff on it. Can anyone offer a better suggestion? THanks
Here's another option:
Intel Core 2 Duo E4300 - $162.99
ASRock 775Dual-VSTA Socket T Motherboard - $57.99
Total: $220.99
Go search around ebay and the For Sale forums for a cheap graphics card. If you don't know which video card to get, here's a link:
http://www.tomshardware.com/2007/02/06/the_best_gaming_video_cards_for_the_money/page7.html
Find your graphics card (5700) and buy whatever graphics card that is a level above it.Or even two levels above it if you can afford it.
Oh and the mobo I recommended has been reviewed here:
http://www.anandtech.com/mb/showdoc.aspx?i=2810
http://www.anandtech.com/mb/showdoc.aspx?i=2813
http://www.anandtech.com/showdoc.aspx?i=2814&p=1
$58 - ASRock 775Dual-VSTA Socket T (LGA 775) VIA PT880 PRO
Here's some reviews on that AsRock board:
http://www.anandtech.com/showdoc.aspx?i=2810
http://www.anandtech.com/showdoc.aspx?i=2813
Summary: DDR400 is fine for now, it won't slow performance. The PCI-E 4x slot only slows down high performance cards by about 10%, which isn't much.
$163 - Intel Core 2 Duo E4300 Allendale 1.8GHz 2MB L2 Cache
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903
$20 - Arctic Cooling Freezer 7 Pro
//edit: ugh, danny beat me to it, lol.:p
LOL! Our posts are only a minute apart from each other
Thanks for your help, I will def be going the route of the Intel cpu.
Does anyone know if this board has overclocking features?
It reaches around 300FSB. So if you pair it with an E4300 or Pentium D 805 (CPUs with high multipliers), it leads to a nice overclock.
E4300: 9 * 200 = 1.8Ghz (Stock), DDR2-400
E4300: 9 * 300 = 2.7Ghz (Overclocked), DDR2-600
