Need Low Profile Northbridge Cooler
lifeinchains
I have a Neo2 Platinum and I need to replace the Zalman northbridge heatsink it currently has with something a little shorter. The Zalman (the tall blue one) worked fine for a while but is currently not up to par with the addition of the dual core cpu. Plus, it doesn't help that I had to cut half of it off to make room for the 7800GS and then more when I went to water.
Therefore I would like to find a copper heatsink to match the black/orange/copper theme I have currently. Through my research I've come upon some very nice forged copper offerings from Enzotech, one low profile and one over twice the height. The question I pose is, will the lower profile sink perform up to the job? Or do I have to resort to buying the taller one and cutting a few pins off?
active cooling will work best,
here is an option maybe you have not considered. This is low profile where the chip is and perhaps you can mount it so the cooling area is out of the way.
http://www.svc.com/hr-05-sli.html
Just a thought.
edit, just saw its nickel plated copper Doh !!! but worth a look anyway, there are others like it out there, maybe you can find a copper one that is not plated.
This is low profile and copper with fan, Lapp it with AS5 and it should do the job but its like the stock one which apparently is not to your liking so /shrug,
http://www.svc.com/vansolcopvga.html
I have considered the Thermalright heatsink and if the copper Enzotech sinks wont cut it then I will pick that one up. As much as I would like a cohesive look, my case doesnt have a window so color really doesnt matter that much in the big picture.
So that short copper sink wont have enough cooling potential for the Nforce3 chip?
That small copper one will be fine for your NF3 board. These little things are great, been using them for a good long time.
I agree, the picture of the OPs board I looked at had one of these small fan dealies on it so I assumed he did not like it, I guess it was an option or I looked at the wrong or newer board version. My comment was based on that assumption his board came with one and for some reason he did not like it and replaced it with the zalman. Totally agree with Rhentno.
