need high end fm tuner
powerade
i got a 50 dollar tv / fm tuner combo and the fm reception is terrible, either all the way in one day but still not as clear or not in at all the next. Yet a budget stereo will recieve all the stations that i want.
so if anyone knows a good fm tuner with perfect reception all the time post em =o
Are you looking for just a tuner section or a reciever w/ a good am/fm tuner? I owned a NAD tuner back in the day that was rock solid. If you look hard enough.. you might be able to find one on ebay for pretty cheap.
what u mean a reciever ??
just need a pci card with a exelent fm tuner i meant
gotcha.. missed the tv tuner part. I had one on my AIW but it never worked. Are you looking just to replace the fm tuner?
What kind of antenna do you have hooked up to the fm tuner? Relocating it or getting a better one could make all the difference in the world.
