Need help
KYELL
I'm going to be building a new comp for the first time very soon and i'm not sure which video card to get I heard that a new generation is coming out in a couple days so i'm not sure if I should wait is a saphire 9800 pro good or what?
a 9800pro is basically bare minimum
I don't even know what agp is but I'm making the computer from scratch and I have like 1000ish to spend not including monitor
agp= advanced graphics port (its the long slot on a motherboard) other than agp the only other "performance" option is if you build a pci-e system
:eek: How? You sure you know what you are doing?
KYELL said:
Do you think prices will drop in a week when the next gen comes out?
if you only have 1000 including monitor just buy a prebuilt dell system and then buy an after market video card
haha thanks sounds good I could use some input look at www.a-power.com that's likely where I will buy most from because prices are good and it's close agreed?
YEah dell does have some pretty good deals but what are the benefits from buying it from them versus building it on my own ?
if you dont know what your doing its better to start by upgrading a system than building one from scratch
True
*Also makes a Neweegg list for KYELL (will post it later this evening)*
agreed but i'm not COMPLEtly computer stupid I can't upgrade my current computer it's just waiting to be put down
just so I know are you both going to post the list in this thread? so I know where to check later
i say get a cheap $500 dell system with a 17in monitor then upgrade the ram to at least 1 gig then get a bigger hdd and then purchase a video card
It seems like the dell computer use intel processors? isn't that worse then amd
DFI LanParty nF4 Ultra-D $135.00
http://www.newegg.com/Product/Product.asp?Item=N82E16813136152
AMD Athlon 64 3500+ Venice $269.99 http://www.newegg.com/Product/Product.asp?Item=N82E16819103533
Corsair Value Select 2x 512MB $79.99
http://www.newegg.com/Product/Product.asp?Item=N82E16820145440
Samsung 120 gig 7200RPM HD $80.00
http://www.newegg.com/Product/Product.asp?Item=N82E16822152017
Sony All-in-one drive $75.99
http://www2.newegg.com/Product/Product.asp?Item=N82E16827-131-244&depa=0
Retail ATI X800XL $329
http://www.newegg.com/Product/Product.asp?Item=N82E16814102543
Antec TruePower II $65
http://www.newegg.com/Product/Product.asp?Item=N82E16817103928
All else you would need is a case...this is your opinion, not mine. This is a pretty much kick ass system IMHO! Enjoy! Also: The SLI mobo is for future expandibility.
yea that would make a nice system
ok well then thanks a lot any suggestions on mouse and speakers while your at it haha
get a cheapo $40 microsoft wireless desktop (keyboard and mouse) i have one and it works great
are you sure i've heard bad things about microsoft mice and keyboards and wireless seems to not work that well
Not everyone has 600 dollars to spend on a video card.
9800 Pro is a good card, although XT would be the favourite, it's recommended for those who wish to play games at high performance, but not excellerated performance.
cell_491 said:
maybe but mine works great
Everything I've experienced from Microsoft mice, and keyboards, are terrible.
Like, generic $5 mice, and keyboards would outperform the shit I've purchased / Seen.
