I am finally ready to purchase parts from my "delayed" rebuild of my computer..but, it is a good thing, as I will be able to get even better parts now.
Here is my information:
"I will be doing alot of 1080/60p:MPEG-4 AVC/H,264 video editing, gaming, web surfing"
"I would like to stay around $1,200.00, but, I can go as high as $1,500.00 total"
3) Where do you live?
"I live in Washington State"
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific
"I need: CPU, Motherboard, Memorey, Power Supply, Hard Drive, Video Card, and Blue-Ray burner".
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model
"I will be re-using my Lian Li PC-70 "Big Tower" case only"
6) Will you be overclocking?
"Medium overclocking"
"24" monitor"
"ASAP"
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
"For now, I'm just going to use the SSD for OS and programs, adding more drives for misc. files/programs"
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
"Now I'm using Windows XP Home Edition, but, will upgrade to Windows 7 64bit"
Priced parts I am considering at newegg, but would like to know equal/better parts for same/less $$:
CPU: i7 930 $289.99
Motherboard: Asus P6X58D Premium $299.99
6 GB Memory: GSkill SDRA DDR3 1600 F3-12800 CL8TU-6GBPI $184.99
Hard Drive: Kingston SSDNow V series SNV425-S2/64GB SATA II $139.99
Video Card: Leadtek MPEG-2/H.264 Transcoding Card $279.99
Blue-Ray Burner: Pioneer BDR-205 BKS (OEM) $184.99
Power Supply: Corsair CMPSU-850HX 850W $169.99
I would like the best build for the money spent. This will be something that will have to last a few years.
I'm not sure if the Video Card is exactly what I need. I don't know how well it will process 1080/60p MPEG-4 type files from my Panasonic TM700 camcorder, as I don't see that file format listed in the "input" section of the cards specs:
.http://www.newegg.com/Product/Produ...5122016&cm_re=Blue-ray-_-15-122-016-_-Product
Any and all help is much appreciated..thanks!
Rick
"24" monitor"
"ASAP"
CPU: i7 930 $289.99
Rick
