- Dec 2, 2009
so im visiting my parents house right now and i was trying to browse the internet on their PC when the computer BSOD. im not sure the reason why it did, but i feel they may have some serious spyware, maleware, or virus.
symptoms are:
1. THe computer takes about 15 minutes to start up
2. on task manager, many of the processes have two versions of themselves open, both taking up a different amount of memory
3. once the computer is started up, nothing runs properly. it constantly runs slow and every aplication will freeze. websites will make the browser freeze, taskmanager will freeze and shut down, the start bar will freeze.
4. if i try to close processes on task manager that are pointless (itunes, windows media, etcetc) afte rabout three, the computer will BSOD.
I have:
scanned the computer with spybot, adaware, malebytes, and CCleaner.
also i have run the antivirus and defragged the hardrive, but there is still no improvment.
Do you guys have any suggestions on what it could be or what else i could do? also is it probably spyware, or is the computer just getting old?
Specs:
dell inspiron
intel core duo E6550 2.33 GHz
3 GB ram
120 gig HD
windows vista 32 bit
probably about 1 year old.
thats about all i know
symptoms are:
I have:
Specs:
dell inspiron
3 GB ram
120 gig HD
