I'm looking to put together a new rig, I haven't built a new PC in like 8 years and i'm totally out of the loop. Everything is different now! It's time for me to get a decent desktop, as the work i'm doing can no longer be handled by an affordable laptop. I'm mostly into audio/video production/editing and some gaming.
Audio editing and in-DAW Production. Cubase, FLStudio, soundforge, adobe products, light gaming.
Under $1,200 if possible including shipping. My budget is semi-flexible but I'm not looking to spend any more than I have to.
USA, Anchorage Alaska.
The case and all that goes into it, except the sound card. I'll purchase that later. Basically, everything in my PCHound link.
Not reusing anything. I'll get the sound card/audio interface later, and I have a mouse and keyboard. I'll decide on a couple monitors or HDTVs after I get the rig together.
6) Will you be overclocking?
Not at this time.
ASAP, I can't do any production work until it arrives.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing fancy for me, usb 3.0 would be nice. Any advice here?
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
I have windows 7, might upgrade. Out of the loop when it comes to modern windows, any advice here as well?
Here's my PCHound link: https://pchound.com/B8vVPa/ I've noticed that other versions of the video card are more expensive. Any Advice on that particular card/card manufacturer? I'm not into heavy gaming, but I'd like to be able to run indie steam games and maybe some older FPSs. Also, how much do you think the speed of my ram will be an issue? From what I understand, it's not a huge deal. Also also, I'm thinking of grabbing a 256gb SSD instead of the 2gb hard drive, come to think of it I have an extra sata drive laying around, anyway. I can just use that as a slave. Any thoughts on the motherboard or anything else? I've noticed that the mobo has a bunch of built in audio stuff, i'm probably just going to be using a sound card anyway, so that stuff doesnt matter and hopefully won't be any weird issues there. Will everything fit in that case? Is there anything you guys recommend changing? Thanks in advance and I appreciate any input. Sorry for the long-winded post.
Not at this time.
