PC is primarily being built to play FFXIV. Will also be for Steam gaming (Dragon Age, Total War, Civ IV), Internet browsing and watching videos.
$750 max t/s incl. but would like to spend less if it doesn't mean sacrificing too much
3) Where do you live?
DFW, TX
Case, CPU, Mobo, RAM, GFX, PSU, DVD burner, HD,
Mouse, Keyboard, Speakers (all standard wired black Dell issue)
6) Will you be overclocking?
No
Have LG 24" Widescreen Monitor
Hope to order before December
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Just looking to have a single 1TB HD and a single GFX card, nothing fancy
Windows 7 64bit
These are the recommended specs for FFXIV that I am attempting to build this machine for.
I am not looking to run this thing at all High settings. I just want to be able to play decently without any issue.
Operating System Windows 7 32-bit / 64-bit *
Processor Intel® Core i7 (2.66 GHz) or faster
Memory 4 GB or more
Storage Install: 15 GB or more
Download: 6 GB or more
Video NVIDIA® GeForce® GTX 460 with 768 MB VRAM or equivalent
Sound DirectSound® compatible sound card (DirectX® 9.0c or higher)
Internet Broadband Internet connection
Resolution 1280 x 720 or higher; 32-bit
DirectX® DirectX® 9.0c
Controls Mouse, Keyboard, Gamepad
This is the system I have attempted to put together but I would like some feedback if there are better options for the money or if something less powerful (and cheaper) will get the job done.
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
$59.95
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard
$99.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
AMD Athlon II X3 445 Rana 3.1GHz 3 x 512KB L2 Cache Socket AM3 95W Triple-Core Desktop Processor ADX445WFGMBOX
$73.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103872
CORSAIR XMS3 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory Model CMX8GX3M2A1333C9
$131.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145315
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
$149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
CORSAIR HX Series CMPSU-650HX 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
$119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
Western Digital Caviar Blue WD10EALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$69.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136534
LG Black 24X DVD+R
$19.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136177
SubTotal: $725.88
Total Shipped: $739.21
DFW, TX
No
Windows 7 64bit
Memory 4 GB or more
$59.95
$99.99
$73.99
$131.99
$149.99
$119.99
$69.99
LG Black 24X DVD+R
$19.99
SubTotal: $725.88
