Need help with new Builds
Cbshahji
ok i'm building 2 PC,and i want to know what is best or not as i'm on budget.
System A:- Video surveillance system,
System B:- Mainly office work (MS office/quickbook) and light gaming (like pogo and once on facebook)
System A:- about $350, tax including, shipping is flexible
System B:- about $450, tax including, shipping is flexible
3) Where do you live?
Florida
System A:- Motherboard, Intel CPU (must be intel), RAM (if go DDR3), big HDD (can be avoided first but will need in later days) GPU (will be nice if i can get cheap ATI to do crossfire just to have 3 monitors (not sure i can clonex3 them but if i can it'll be nice if not other cost efficent method is fine in which case on board GPU is fine, but clonex2 is must , will settle for clone on 2 monitors)
System B:- Motherboard, CPU (good to last 5 years of office work), RAM, DVD writer (can be added later)
System A:- Case, PSU, cables, keyboard, mouse, monitor
System B:- Monitor, Keyboard, Mouse GPU, SSD (have to so my sister can enjoy speed) IDE HD for backup data and storage.
6) Will you be overclocking?
System A:- Doesn't have to but keeping option open if i can lower the price.
System B:- Doesn't have to but keeping option open if i can lower the price.
System A:- has one 19" and second 21.5"
System B:- Has 19" dell IPS atm but will like to get bigger on later dates for more pixels (doesn't need to be IPS) the monitor will be off of the budget so is not a problam.
System A:- next 3-6 month
System B:- ASAP, but can delay as long as a month if better futures are available.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
System A:- not much but Raid will be good and can handle 3TB had will be great one PCI-Ex1 and PCI card must, micro ATX is fine and prefered.
System B:- USB 3.0 and SATA 6Gb/s is good option but not necessary, and micro atx is fine too
already have 32 bit W7HP
on one more note gonna need little help with PSU for both systems. for system A and B lowest wattage PSU is must as i won't be adding much of the options later on.
For system A and B i would like to have good 1155 MB and i5 2500 is good (for survillance system it is good requirement and for second one i would like to have it compare to other quad cores and dual cores (1366 is great i know but it's too much), also have 9600GT for system B which will do great for good work.
for system A cheapest ram is fine as long as they are good (if i get the $9 deal soon i'll get 4 sticks of 2GB), for system B i would like to have solid ram.1333 is last resort for it (4GB good ram is good).
Ok, you're planning system A way way too soon. The parts we recommend today may not be the best parts to buy a month from now let alone 3-6 months. If you want good up-to-date advice on that build, ask for advice on that setup 2-3 weeks before your actual buy date.
As for system B:
$220 - Intel Core i5-2500K CPU
$108 - MSI H67MA-E35 (B3) LGA 1155 Intel H67 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$18 - LG iHAS124-04 DVD Burner
$45 - Antec NEO ECO 400C 400W PSU
Total: $432 shipped
Thanks, i actually planned to build right now if i can get it under budget, and i was just wondering if i can get it under budget. as for up-to-date goes i would like it capable rather than top knotch for it. thought i found good second hand system for A so i'm gonna go ahed with the plan right now.
for system B, yep i'm gonna look for little more as the MB has onboard graphics and since i've good graphic card i would look around see if i can get one without it and good one second hand on FS forum. the PSU
Thanks for the help
As for system B:
Total: $432 shipped
Is it better to go with 1 stick (4gb) than 2x2gb?
And why the 2500k with h67 instead of 2500? Trying to figure out a similar build.
The price difference was only $10 on Newegg. So figured just in case the OP ever decides to swap mobo and wants to OC...
