Need help with new buiild
Nimrod
Alright I just need help with picking some parts the price doesn't include monitor, keyboard, mouse, windows, or case
I kind of have what cpu I want to use in mind as I've read nothing but good things about the i5 2500k but other than that not sure what I want to get so a little help would be appreciated
Web browsing, watching movies, and light gaming
Don't have a set price but would like to stay anywhere from 500-750
Ohio
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
Cpu, Mobo, Ram, Video card, Power Supply, Hard drive
Already have a case
6) Will you be overclocking?
No
Don't have one yet but plan on going no bigger than a 24
Next weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
I Don't need Raid or Crossfire/Sli
Yes
Do you live near a physical Fry's or Micro Center store? Do you have a local mom-and-pop store near you?
Which specific case are you reusing? Which version of Windows do you have?
Are you buying the monitor at the same time as the rest of this build?
Define "light gaming" for us... which games do you play? At what level of visual quality?
Are you watching HD (720p/1080p) videos? Do you want to play back Blu-ray movies?
No I don't I plan on ordering from newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156078 using that as a case and Windows 7 64 bit
I'm buying a monitor at the same time but that isn't included in the price budget that I listed
Light gaming I just mean if I want to play a game then I'll be able to play it I'm not real picky and it doesn't have to be the highest settings
I want to be able to playback blu-ray movies
How does this look
Intel Core i5-2500K
Patriot Signature 8GB (2 x 4GB)
EVGA GeForce GTX 550 Ti
ASUS P8Z68-V LX
Antec High Current Gamer Series 620W
