Need help with motherboard
ern
This is what I have chosen so far. I just need help fitting in a board that is compatible yet inexpensive and reliable.
EVGA 512-P3-N801-AR GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card - Retail
Antec Three Hundred Black ATX Mid Tower Computer Case - Retail
AMD Athlon 64 X2 6000+ Windsor 3.0GHz Socket AM2 125W Dual-Core Processor Model ADX6000CZBOX - Retail
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400 - Retail
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM
***Here are 2 that I was looking at.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128081
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128090
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128075
Looks like those 3 had good reviews and seem to have alot but not sure what the major differences are.
All should be good boards. Really, the main differences are #1 is full ATX, #2 microATX, and #3 has CF capability. Didn't look at any minor differences in the connections or other extras, but those should be listed in the Newegg entries. The GB website also has a good comparison chart for its boards; check that out, too.
I have narrowed it down to the 1st 2. Im not sure which one to get. They look identical other than one has more expansion slots.
What do you guys think?
The one is mATX, so it is a smaller board.
Chances are you won't notice any difference between the two boards. If you need room for expansion, get the full ATX board. Otherwise, the mATX should be fine. I've used several mATX Gigabyte boards and they've all worked great for me (on one now).
