need help with gaming build
poskey
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? mostly gaming, listening to music (musician,bass player) web surfing. have speakers but would like suggestions on sound card.
[/COLOR]2) What's your budget? Are tax and shipping included? 1800.00 including tax and shipping.
[/COLOR]3) Which country do you live in? If the U.S, please tell us the state and city if possible. lawton, oklahoma
[/COLOR]4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. case, cpu, power supply, ram, motherboard, gpu, 2 optical drives, 1 hard drive, cpu cooler (would like to do slight overclock),o.s. (windows 7 64 bit)
[/COLOR]5) If reusing any parts, what parts will you be reusing?
Not reusing anything
[/COLOR]6) Will you be overclocking?
yes
[/COLOR]7) 7) What is the max resolution of your monitor? What size is it? 30" eventually. right now 23" 1920x1080
[/COLOR]8) When do you plan on building/buying the PC?
1 or 2 months
[/COLOR]9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc. only want to run 1 video card
[/COLOR]10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? win7 64 bit oem. i dont think i can install on another p.c.?
usually keep a system for 3 or 4 years upgrading the video card and sometimes adding ram. so will need some headroom for doing this. thanks so much for your help and time.!
1 or 2 months
Since you have a bit of leeway there in time, I recommend that you please come back in late April/Early May and ask for advice then. By then, Intel's new Ivy Bridge CPUs and Z77 motherboards will be out. Since you plan on keeping the system for a long time, might as well the extra months so that you can get as much performance as possible.
