Need help with F@H Server wont connect
Rustedimpala
Hi yall. One of my rigs cant get a work packet. I checked the log file and its trying to get it from 171.64.122.112. So I checked the server status link at F@H and it says its on standby and not accepting. http://vspx27.stanford.edu/serverstat.html
Is there anything I can do, so that I can stay productive. How do you change which server you recieve WUs from?
Thanks!
Mayhem33
It will change servers on its own....sometimes it can take a little bit but be patient....it will go through! Stanford has a server set up to handle these WU that can not return to the server they came from.
Just hang in there....it will sort its self out befor too long! :D
Rustedimpala
Thanks, I'll just leave it running then. Its been trying for a long time though.
Majic
Can always run 2 instances of folding to protect against those type problems and with your sig system should be no problem.
Rustedimpala
The one in sig is the one that is down. Is it possible to run 2 instances on the same rig?
Mayhem33
Rustedimpala said:
Its been about 6 hours now, according to the log file. I noticed it about 5 hours ago though.
Man that really does sux! Hang in there though......it will stop waiting for the right server and go on to the collection server. It may also just hold it in cue and get another WU...hopefully it decides quickly! ;)
Majic
YES there is.
Make a second folder named like fah2 install folding in this folder while doing the config the very last question is machine id= set this one to 2 where as the one not sending would be one. this is very much the same setup you would use on a dual system of a dial-up system to cut down on the amount of times you have to dial-up to get or send w/u's.
Rustedimpala
Yeah it does suck. Ive been trying my best to increase my WUs. Im working on a couple more boxes. I just ran out of money. Hopefully next week I can get them finished and up and running.
Mayhem33
Majic said:
YES there is.
Does that ever cause problems like the 2 instances running at the same time...not bustin your chops here...I really want to know!
Rustedimpala
Ok I installed another copy into folders that are labeled F@H2. But it wont let me run 2 instances at the same time. Did I screw something up? :eek:
Ok I just checked the logfile of F@H2 and its trying to get the wu from the same server. It wont connect. DOH!
Majic
you can try deleteing everything but the config file and the .exe and run it again till you get something. /shrug hehe
Mayhem33
Patience grasshopper! :p j/k
Rustedimpala
I'll leave it running and check it out in the morning. Maybe it will work itself out. Thanks for the help though. :)
Rustedimpala
It just connected and download a WU. I checked the log file and it looks like the server just came back online. Thanks for the help.
