desertjedi
- Feb 29, 2008
Thanks for reading my long post...
I start editing photos on my new Planar 20" MVA-panel LCD but the pics were very cold and I knew I needed to calibrate. So I calibrate with the Spyder 2 Suite and the "coldness" in the pics in Adobe Lightroom is gone. Pics look just like they did on my previous LCD.
So I'm looking through Preferences in Paint Shop Pro 8 and I find a Color Management option. I open it and see that Color Management (the use of color profiles) is an Option. I thought that as soon as I "kicked in" the new color profile, everything would be affected. So I enable Color Mgt. in PSP 8. The good news is that colors seem a perfect match for the colors in Adobe Lightroom - which I use for "first pass" editing. It appears that Lightroom doesn't require you to turn on Color Management but Paint Shop Pro 8 does.
So during this whole process, I decide to calibrate my LCD for my gaming rig which is on the "other side" of my KVM. I create a profile and crank up a game. But I can tell the game looks really cold just like it did before. I ALT-TAB out and can see that the color profile is not "in effect". Damn!
So is the bottom line that only certain software can make use of color profiles either explicitly like Paint Shop Pro or implicitly like Adobe Lightroom? Apparently, the game I loaded simply "flushed out" the profile info from the video card when it started. Is there anything I can do to prevent that? As soon as I exit the game, the color profile is back "in effect". My current solution is to use the color profile on my business box but tweaking the color globally on my gaming rig with the Nvidia Control Panel. Anyone know how to calibrate an LCD by eye?
To top things off, in all this "color work" I find that the left side of my LCD is colder in temp than the right side so I'm exchanging it for the same LCD (only option).
I guess I was very lucky to have been using an LCD for almost 3 years that had exceptional color right out of the box - my trusty 19" Viewsonic VP930b. What a pleasure to use!
