Yay for first post asking how to build computers. =LD
>> totally not implying that I won't be active on the forums trololol.
1. What will you be doing with this PC?
The primary one will be used for photoshop and maya. I don't game too much now-a-days, but if I do, its EvE 90% of the time.
The second computer will will serve like a back-up computer. E-mail and browsing the internets. I'm going to throw photoshop on here for any situation my main one goes out the window.
2. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
$1,500 ± 300 after tax and shipping. If I can get away with it cheaper, the better.
3. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
There are plenty of computer chains nearby me. Some more reputable than others. Though for specifics, I lives in Canada.
4. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need.
EVERYTHING!!!!!!!!1111111 jk
Cases, motherboards, processor/s, videocard/s, powersupply/s,
5. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
To try and keep costs down, salvageable parts (not necessarily using them all) I have at my disposal are...
AMD Phenom II x4 955 BE
AMD Athlon x2 3800+ (might be dumping)
4x4 GB Corsair XMS3 RAM 1333 cl9
2x2 GB Patriot Sector 5 RAM 1333 cl7 (One of them I need to fix the heatsink)
2x1 GB DDR2 RAM (might be dumping)
Thermaltake 850w TR2 RX PSU
Zotac GTX 285 (might be dumping, been getting too many compatibility problems)
Hard Drives (I seem to have a farm of Sata/Sata II/IDE HDDs in various sizes)
6. What specific features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
*required*
USB 3.0
I've been getting more usb 3.0 external HDDs, and will be expecting to use more usb 3.0 accessories.
Relatively Small
Lacking room for my full/mid towers. I also prefer horizontal over vertical layouts.
*wanted*
Sata 6.0 Gb/s
Been reading that the mainstream SSDs are having a hard time beating 3.0 Gb/s.
Fast read/write
7. What resolution output do you need? 1080p, 720p, DVD quality, etc for HTPC or list Vertical/horizontal resolution for non-HTPC SFF rigs. Do you need multiple monitor output?
1920x1200 for both computers, and dual monitors for I'll be using a cintiq + montior.
8. Does this system need to fit into a particular space? Think entertainment center shelves, closet space, rackmount, etc.
Coffe table and dufflebags. =D
9. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
I am very comfortable with modifying my case, though my skills may question me otherwise. I have access to plenty of handheld tools minus welders.
10. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Quieter the better. Don't have access to sound rooms.
11. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Weight isn't too much of a concern, but if it hasn't been implied already, it needs to be semi-mobile. Needs to fit a duffle bag.
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
Windows 7 Ultimate 64 bit
Windows Vista Ultimate 64 bit
13. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
I need one capable of running Photoshop and rendering low poly count on Maya almost immediately. A stronger one for 100k+ poly count not until later in the year. (looking at Q3-4 of the year)
Ideas?
*required*
USB 3.0
Relatively Small
*wanted*
Sata 6.0 Gb/s
Fast read/write
Ideas?
