Need help with Autocad Revit Build
marley1
Hey guys, one of my clients wants to upgrade to Autocad Revit 2010 which is suppose to really use the computers. I have posted on an Autocad forum and the cards recommended or listed at working are Nvidia GeForce GTX 560 Ti (1 GB), Nvidia GeForce GTX460 (2 GB), Nvidia GeForce GTX460 (1 GB). The forum also recommends 12GB of memory and a i7.
Now this is a business machine so if I can get any parts that come with 3 year warranty that would be great. I do not want AMD for a processor. I also would like to get a mid tower case, something nice since it is a office environment. Need it to be cool as well, so OEM cooler is fine.
- Office 2010, Internet Explorer, Photoshop, Web Browsing, Autocad Revit
- Need to get a fast machine that can last the 3-4 years, something reliable, as in-expensive as I can go, but it is looking like we will be around $2000. I usually order everything from NewEgg
3) Where do you live?
- New York
- Actually everything =). I need the case (need a nice looking case, not a huge case at that), motherboard, CPU, memory, videocard, DVD Burner, powersupply, operating system
- No re-use
6) Will you be overclocking?
- NO
- Think they have dual 20" LCD
- As soon as it gets approved
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
- Reliability
- No, need Win7 64 Bit
Can you confirm the monitors being used and their resolutions?
Since you said "everything," do you also need a new keyboard and mouse or speakers? An external HDD or NAS?
I think the screens are Dell 20" Widescreens the E series, 1680x1050.
I believe we have speakers, and new keyboard and mouse.
So just the computer tower and innards.
I could probably go research everything, but last time i had a build this was the best way to get advice.
$420 - Intel Core i7 2600K CPU + Windows 7 Professional 64bit OEM Combo
$140 - MSI P67A-G45 Intel P67 ATX Motherboard
$150 - G.Skill Ripjaw Series F3-10666CL9D-8GBRL 8GB DDR3 1333 RAM + Corsair 650TX V2 650W PSU Combo
$80 - G.Skill Ripjaws F3-10666CL9D-8GBRL 2 x 4GB DDR3 1333 RAM
$235 - eVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB 1GB PCI-E Video Card
$240 - Intel 320 Series SSDSA2CW120G3K5 2.5" 120GB SSD
$65 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$21 - LG iHAS124-04 DVD Burner
Total: $1351 plus tax and shippping.
Notes:
- Keep the OS and applications on the SSD. Keep data and large sized program installations on the HDD
- Yes that's 16GB of RAM :)
- Went with Windows 7 Pro for its better integration into a business class network and the fact that the price difference between Pro and Home Premium wasn't that much.
Choose your own case. I recommend the following:
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
$70 - Lian Li Lancool PC-K58W ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$100 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$90 - Lian Li Lancool PC-K7B ATX Case
$106 - Lian Li PC-7B Plus II ATX Case
$127 - Fractal Design Define R3 Black ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$165 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
$220 - Corsair Obsidian Series 650D ATX Case
$220 - Cooler Master ATCS 840 RC-840-KKN1-GP Full Tower ATX Case
$230 - Silverstone FT02B ATX Case
$220 - Lian Li PC-A71F Black ATX Case
$290 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
$330 - Silverstone Temjin SST-TJ07B Full Tower ATX Case
That looks good. I am not a fan of MSI boards, is there a comprable Intel or Asus board?
And what about one from Asus?
Probably one of these three mobos:
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007627%20600093976%20600036416%2050001315&IsNodeId=1&bop=And&ShowDeactivatedMark=False&CompareItemList=280|13-131-708^13-131-708-TS%2C13-131-710^13-131-710-TS%2C13-131-711^13-131-711-TS
This one looks good P8H67-M EVO (REV 3.0), like that it has the 3 year warranty on it as well.
Would that be a smart model to go with with the rest of the parts you listed? Is 650 watt enough? If I had to add another videocard in the future would this MATX board support it?
Is most stuff going to MATX?
It's a good enough model to go with. It has a second PCI-E x16 slot so should fit a second card fine. However you won't get SLI. The Corsair 650TX V2 is more than enough power for that setup.
What would I need to do if I wanted SLI? Is there a ATX board you recommend?
Not sure why you need SLI. Does Revit support SLI? SLI only benefits games last I checked. Not to mention that you don't need SLI or Crossfire for multiple monitors
On the off-chance that Revit does support SLI, I recommend this mobo:
$155 - MSI P67A-GD55 Intel P67 ATX Motherboard
Yes that's a MSI but Asus' offerings in that price range aren't exactly good considering all the issues that's plaguing them.
Just wanted to say thanks. I ordered all your parts, lots of boxes =)
