Hello.
I have an emachines tower model ET1331g-05w with all standard stuff including the original 300 w power supply. I am using an Nvidia GT 220 graphics card. For the most part this does every thing I need it to do for now. I"m using windows 7 home edition 64 bit.
I recently had to replace some RAM and now while playing games after about 20 minutes the screen flashes black a few times I get Kernal errors, crashes to desktop, or gives me a blue screen.
After some research I found this is a conflict with the card and windows I've seen several fixes, but, nothing that I really want to try. (changing fan speeds, changing memory HZ)
I Also use my Toshiba Television as the monitor for the pc. My question to you is, Can you suggest a graphics card that will perform the way mine did before the conflict started that will work with my current set up?
I'm looking to spend as little as possible (under $75 if I can) and would like to get a card without needing to update my system.
Thanks for any help you can provide.
