Friendlypirate80
- Apr 4, 2005
i recently purchased a system from a friend of mines for 400 bucks it has a
Unknown Athlon XP processor but its clocked at 2.4 ghz
ASUS A7N8X-E Deluxe Socket A NVIDIA nForce2 Ultra 400 ATX AMD Motherboard
and a geforce 6800 ultra AGP
not bad for 400 bucks huh ? anyway here is my problem i wanna do a fresh format on it but i cant
also the hardrive is a SCSI hardrive i am not familer with those drives ? im only use to IDE and SATA
when i try to format it wont detect the hardrive and does not allow me to format and install fresh i cant tell the name of the hardrive either can anyone help me :-(
i can get into windows xp just fine just wont let install a new copy :-(
btw the computer speaks to me during bios ! during the boot sequence it says " loading Operating system through my speakers wierd huh never had that before on my old comps ! would that be th emotherbaord or a third party program ?
thanks for any help
thanks for any help
