TheCheatOnBass
- Dec 16, 2008
I've been out of the PC hardware loop for a while now, so I need you guys' help.
First off though, I'll be using this PC for web browsing, music, and nothing too processor heavy. Gamewise, I'll be playing old games like WoW but I'd also like to be able to play newer ones such as World in Coflict (but medium to highish settings are fine, graphics aren't really my priority).
Budget is $500 including shipping, I can go over max. $20ish if it's really worth it. I want to order everything from Newegg to keep it simple.
I already have a monitor, OS, a wireless adapter, keyboard/mouse, and I'm reusing a 200GB hard drive. So I'd need:
CPU
RAM
Motherboard
1 CD/DVD burner
Graphics card
Case
PSU
I think that's all.
From what I've gathered, this combo would be nice
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.147991
And this RAM looks good to me
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
I'm pretty lost on the GPU and PSU. The last time I ordered a card was when the 8800GT was the best bang for you buck, and it still does me fine. I'm not sure what kind of card I could manage with my budget though.
Um, for other info, I could overclock if a heatsink/fan fit in the budget (I have a tube of AS5 lying around here somewhere). I'd be using two monitors, one 19" at 1280 x 1024 and the other at 1400 x 1050 (I think). I want to buy the PC tonight, and receive it by Christmas.
And an unrelated question: what external hard drive would you guys recommend under $100? Nothing related to this build, just out of curiosity.
Thanks in advance, it's the first time I've asked for advice here.
CPU
RAM
Motherboard
1 CD/DVD burner
Graphics card
Case
PSU
I think that's all.
