Had started this post in a different section but was suggested to move it here!
I am building my first computer completely from scratch, in the past I have used bare bones kits etc to do my dirty work, but I am new to the forum and definitely new to a lot that building a new computer has to offer. I would love it if some people could list all the parts needed for a good build that was between 1300 and 1500 dollars for JUST the PC, no software or other hardware needed. Also, I have no idea what the benefits of overclocking is, or how to do it, so any info on that would be helpful.
Some helpful info:
The computer is going to be used for gaming completely, I am located in Michigan, so I was thinking about getting everything from Newegg or Tiger Direct, if anyone knows of a better of cheaper place / way to get the computer, please let me know... Also, I am going to be purchasing either the http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3742982&CatId=2775 or the http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3424386&CatId=2775 for my gaming monitor. So, the computer will have to be compatible with whichever of those I get.
Thanks!
May the best build win
Some helpful info:
Thanks!
