So I have been asked by a friend to help her build the best possible computer for $600 that would allow her to do all her normal things like Facebook, watch movies, check emails and so forth. She also mentioned she wanted to play some games such as Diablo III, Skyrim and others that I may suggest to her. My problem is that I have only $600 to get this done and everything is needed to be purchased including a monitor. The only thing I might be able to get a hold of without purchasing is a case. Already have a keyboard/mouse to give her.
Just as a quick note I want to say that I am fairly close to Micro Center which I know seems to have the best pricing on CPU's.
CPU: Thinking AMD Phenom II X4 965 Black Edition, but not set. Was told i3 might be better?
Motherboard: Must have onboard sound.
Memory: 8gb
Video: Thinking 6870, but not set.
PSU: ~600watt needed in case she wants to learn to overclock as well.
DVD-RW: Any is fine. Cheaper is better.
HDD: 500GB is fine. Sadly hdd's have gone up in price and stayed there.
Case: Not 100% sure this is needed as I might be able to get one for free.
Monitor: At least 19-20in, but larger wont hurt if price difference is small. I have seen a few 21in for $130.
OS: Windows 7 64bit not counted into the $600.
Any help and/or suggestions are greatly appreciated. I have never had to build a system for someone with such a small $ limit.
Memory: 8gb
