Need help, upgrading to i7
wiregen
This is strictly for gaming and Raw video encoding machine. Gaming would be like WoW, Upcoming Games, Mass Effect 2, Bioshock 2, etc.
My upgrade budget is around 600 but give or take. I want quality components but great value.
3) Where do you live?
Minneapolis, I have a microcenter here.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, I don't know if I should go 860 or the 920 route, RAM, again cpu specific, PSU, MOBO, must be able to run my 4890s in crossfire, and raid0 support, I an H50 im going to reususe also.
Lian-li V1200 case, 2x 300gb Velcioraptors, 1x 4890 (going to buy another 4890 to crossfire, see my reasoning below) I'm going to be giving my old Q6600 build to my brother.
6) Will you be overclocking?
Yes
27" iMac display 2560x1440 (only the 4890 and the 5970 are confirmed to work in target display mode for this) So I'm going 4890 crossfired.
This week
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I must have crossfire. I also need RAID so I can raid 0 my Raptors.
You want an I7-920
You should be looking for :
920
6gb -ocz gold (1.65v or lower), corsair, gskill ram
Arock X58 Extreme or Asus P6T
Antec New Truepower TP-750 or Corsair 750
Going for the Corsair 750HX. Still looking for recommendations on a good ram/mobo/cpu combo
GIGABYTE GA-EX58-UD3R LGA 1366 - 188.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128423
i7 920 - $220 after tax Microcenter
Corsair 750HX - 149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) - 159.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145258
total = 718.97
From my understanding the Gigabyte board can do Crossfire and RAID 0.
Overshot the $600 price but I'm fine with this. Is this good?
total = 718.97
Yes you should be happy with those parts.
ok, your mobo link is wrong. You listed the old UD3R mobo but linked to new UD3R mobo which costs another $10. I recommend spending the extra $10 for the newer version since that extra $10 gets you:
- USB 3.0
- 6 RAM slots rather than the 4 of the old UD3R.
- 2 x SATA 6Gb/s
The above features are totally worth the extra $10.
Other than that, looks good to me.
- USB 3.0
- 2 x SATA 6Gb/s
oh look, they finally fixed the UD3R X58! w00t! I agree, definitely worth the extra $10.
