Need help trying to ID a case from 2004
Incramus
I'm trying to find a manufacture/model/part # to a case that I had back in 2004 or so and I'm hoping that some of you guys that have been around for a while might be able to help.
Luckily I found a pic of one that's spitting image but mine didn't come with any of the foam so I think "AcoustiCase" might have just re-branded it?
http://www.acoustiproducts.com/en/acousticase_c6607.asp
Sure it wasn't a Chieftec Dragon or whatever the OG company was for that case? I saw Antec cases any many others that were identical to that style just without the door.
The one kirby posted has was rebranded by pretty much every manufacturer. I had a thermaltake and koolance version personally.
Definitely not the chieftec dragon. Dragon had dual 80mm intakes and the cages didn't go to the floor, they were attached to the front steel panel. Current system is built in a black dragon :)
