Need help to find a Windows 10 compatibility link
Discussion in 'Operating Systems' started by Happy Hopping, Mar 19, 2019.
  1. Happy Hopping
    Happy Hopping [H]ardness Supreme
    6,601
    Jul 1, 2004
    I read it either in this forum, or elsewhere from a link on Microsoft
    it says PC comes out 2 year before win 10 comes out, is compatible with win 10. It is not the win 10 hardware compatible list page.
    It's more of a guarantee page from microsoft
    but when I try to google it, I can't find it anymore
    can anyone help?
  2. Dodge245
    Dodge245 Limp Gawd
    182
    Oct 8, 2018
    vegeta535 likes this.
  3. bigdogchris
    bigdogchris [H]ard as it Gets
    17,889
    Feb 19, 2008
    An easy way to know is to go to your computer manufacturers support site and look at the drivers. If Windows 10 is an option that you know for certain it has support. But even if only 8.1 or 7 is a choice there is still a good chance it will be supported.
    You can also just run the Upgrade Assistant in place over your current OS from within Windows. If there is a problem it will error out and tell you what hardware is not compatible. If fully compatible, the update will be able to complete. Then you can do a clean install after.
    DeaconFrost likes this.
  4. Happy Hopping
    6,601
    Jul 1, 2004
    In the end, I kind of found it:
    https://www.microsoft.com/en-us/win...fe-support-information?icid=CXSMC_win7upgrade
    The link is not for me. I have some clients who got some rather old PC, they need to know what is the age limitation of their PC in order to run properly. A few months ago, I read microsoft said 2 year, now the above says 3 yr.
  5. Dodge245
    Dodge245 Limp Gawd
    182
    Oct 8, 2018
    Its bunk though, I was running windows 10 on an AMD 4400, that was released in 2005. 10 years, from the release of Windows 10.
    Your best bet is to recommend running the Upgrade Assistant.
  6. Happy Hopping
    6,601
    Jul 1, 2004
    I also seems to run into a different problem. I want to check at Lexmark whether such and such laser printer support win 10. It seems the website won't allow me to view whether it has win 10 driver unless it detect my PC has that lexmark printer. So I have to check at the client's site
  7. pendragon1
    pendragon1 [H]ardForum Junkie
    13,894
    Oct 7, 2000
  8. Steve1123
    Steve1123 n00b
    34
    Mar 12, 2016
    The best and the simple way is to go ahead and run the Upgrade Assistant on your current system and it should tell you everything about the system compatibility. and if you think if you can still get a free upgrade
    then simply back up your data and from here, you’ll need to create a Windows 10 installer by going to https://www.microsoft.com/en-us/software-download/windows10/ and then configuring the installer (Create installation media for another PC) with your desired hardware. Use ISO file if you plan to burn it to a DVD or USB flash drive if you’d rather install it from a USB device. You’ll also need to select 32 or 64 bit versions of Windows.
    hope this helps
