Need help setting up correct boot disk on my new build
frankles
Hi All,
I just finished setting everything up with my new build, but had a bit of an issue with installing Windows 7. None of the physical dvds I had lying around (Vista and 7) were in great condition, and neither would make it through the setup phase.
I had planned on using my old SATA drive as a dump for music and stuff, but since I knew I had a W7 Home Premium download (no iso) on it, I booted into my old Windows install and ran the setup from there, with my new drive being the installation target.
Now I've got two perfectly fine Windows 7 installs, one of my new drive (D:\) and one on my old drive (C:\). Thing is, when I go into the BIOS and flip the hard drives around so that my new one is C:, it doesn't boot into Windows because it says it has no boot file. If my old drive is set to C:, I get the Windows Boot Manager and can select my new Windows install on my D: drive and everything works perfectly.
I would like to be able to get my new drive to be the primary bootable drive with the drive letter C: . Is there any way to accomplish that short of getting a bootable W7 disc and reinstalling? I bought Home Premium from the Digital River site when it was made available to students but I didn't see an ISO option so I just have an .exe with 2 other large files. There is another folder in the directory that looks like it has boot information but I don't really know how to take all of that and burn a bootable dvd to install with. Any help would be greatly appreciated!
Just for reference my new hardware is:
Intel Core i5 760
ASUS P7P55D-E
4GB Kingston DDR3
EVGA Geforce GTX 460 1 GB FTW
Samsung Spinpoint F3 1TB (new hard drive)
old random 320 GB SATA
Google "Easy BCD" and gogle instructions on to use it. That should help you.
