Need help selecting motherboard for 2700~$ new machine
Hello, I know very little about computers, and my 1-year-old computer got stolen so I'm building a new one, financed in part by my insurance company. I am required to buy it from a specific store, so don't worry if the prices are higher than expected...
I think I got a good handle on what I need, but I know nothing about motherboards, cases and power supplies, and the technical terms are a bit too complicated for me. Could you please suggest some motherboards for this setup?
Requirements:
-I will never overclock
-No need for SLI/Crossfire
-Not sure I need on-board sound, my old computer had a Creative Gamer Paperweight so I plan to get a new one
-Do they all come with 4 RAM slots? I plan to get either 2x2gb, or 4x2gb
-I don't understand the pros/cons of DDR2 1066mhz or DDR3 1333mhz RAM. So I don't know what I should get here...
Candidate setup:
169$ - OS: Vista 64bit Business Edition
225$ - CPU: Intel Core 2 Duo - E8500 - 3.16G/1333/6M/S775
325$ - Video: Sapphire Radeon HD4870 512mb
329$ - Application Drive: 300gb Veloci-Raptor drive
179$ - Storage Drive: WD or Seagate 1TB cheapest drive
35$ DVD burner/CDR
99$ - Sound: Creative - X-FI Extreme - Gamer
45$ - Keyboard: Logitech Wave
85$ - Mouse: Logitech G9
85$ - RAM: Kingston KVR 800MHZ DDR2 NO-ECC 4096MB
Please advise on a motherboard and possibly RAM as well.
I have an ABit IP35-Pro and I'm very happy with it - I do overclock but even if I didn't its a very nice board. I think the Asus Maximus boards are also really nice and more expensive. As far as DDR2 vs DDR3, I don't think it makes a ton of difference really - except DDR3 is still a lot more expensive.
I'd go for 4x2gb of DDR2 - if you're running 64bit Vista, the OS will be just fine with that much memory.
I might spend a little more on the CPU and get one of the new quad cores - not overclocking with an E8x00 CPU, you're missing out. The Q9450 etc are quad core and if you intend to run at stock speeds, why not 4 cores @ stock rather than 2? :)
Don't worry about DDR2 1066/DDR3 1333. You should just stick with DDR2 as there's no benefit for going with DDR3, DDR2 800 is plenty fast enough as you don't really see any performance gains at running the ram faster than the FSB, since the FSB is only going at 333 and you aren't OC'ing you don't need anything faster than DDR2 667, that said the ram you listed is a good pick.
Personally I'd go with a quad core CPU, especially if you want to keep the system for a few years.
For mobos go with a P45, the Asus P5Q series are great choices, the Gigabyte and DFI boards are also solid choices.
Thank you for the suggestions... and just to make sure: There are no boards that will take advantage of 1066 DDR2 without overclocking?
For the processor, given how cheap they are and the marginal benefits of quad core for what I do (gaming only, no video stuff), I figured I'd stick with the 8500 and upgrade in a year or two, when there will be significantly better stuff for 200$.
However I will reconsider this and look up benchmarks for games I'm likely to play (FPS mostly) for quad cores...
In a year or two you may not have a ton of socket 775 options - best bet is get the most CPU bang for your buck now - and that tends to be a quad core, especially if you're not going to overclock. That way in 2 years, when more things take advantage of multiple cores, you're not sitting there wishing you had twice the cores for $50 two years ago when you built it. ;)
Well if you are sure you're only going to be gaming the e8500 is a good choice.
The thing on the ram is there's no point in running it faster than your FSB, at default that's not going to be more than DDR2 667, if you OC to a decent level that's still not going to be more than DDR2 800/DDR2 900.
There are motherboards that support DDR2 1066 RAM. It's just the CPUs won't take advantage of that RAM unless you're doing some overclocking.
I would say a asus rampage formula(x48) or asus p5q-deluxe(p45),these are both very good boards whether you are ocing or not.If you are spending that much on your pc,you may as well get a high quality motherboard.
+1 for the Rampage Formula. You can run 8 gigs with it, it OCs very well, and is rock solid stable.
EDIT: Just saw you don't want to OC or crossfire, but regardless, my rec. still stands.
It's funny because frankly I don't even know what kind of difference a board makes, aside from forward compatibility.
By the way, my stolen one was a P5B-Deluxe. I don't know if that's the reason why my computer ran well or not :)
How much of this rig is financed by the insurance company? All $2500 of it or just a part of that?
A motherboard determines the overclocking capability, and to a lesser extent, performance of the motherboard. IN addition, a good motherboard will lessen the chances of stability problems down the road. However, don't expect any motherboard bought today to be compatible with any new CPU coming out in the next six months as both AMD and Intel are switching to new sockets.
Power supply wise, I recommend these two power supplies if they're available at the store you have to buy from:
Corsair 750TX 750W PSU - $98
PC Power & Cooling Silencer 750 Quad 750W PSU - $135
And some case recommendations:
Cooler Master Elite 330 RC-330-KKN1-GP ATX Case - $39
Cooler Master Centurion 534 ATX Case - $45
Cooler Master Centurion 532 ATX Case - $50
Cooler Master Mystique RC-632S-KKN1-GP ATX Case - $57
Antec 300 ATX Case - $60
Cooler Master RC-590-KKN1-GP ATX Case - $60
Cooler Master RC-690-KKN1-GP ATX Case - $60
Antec Solo ATX Case - $84
Lian Li Lancool PC-K7B ATX Case - $90
Lian Li PC-7B Plus II Silver ATX Case - $100
AeroCool Masstige ATX Case - $105
Antec P182 ATX Case - $135
Thermaltake Armor VA8000BWS Full Tower ATX Case - $125
Lian Li PC-A16A ATX Case - $150
Coolermaster Cosmos 1000 RC-1000-KSN1-GP Full Tower ATX Case - $157
Cooler Master Cosmos S 1000 RC-1100-KSN1-GP Full Tower ATX Case - $230
Lian Li PC-V1200 ATX Case (Silver) - 180
Lian Li PC-V1200 ATX Case (Black) - $214
Lian Li PC-V1200B Plus II ATX Case - $215
Lian-Li PC-V1100A PLUS II ATX Case - $220
Lian Li PC-A71B ATX Case - $225
Another Rampage vote. Not only is this board the most stable one I have used it is also one of the easiest to use. I would also suggest a quad cpu and a Pc Power & Cooling Silencer 750 quad like Danny suggested.
All of it will hopefully be financed.
I'll check out these cases and power supplies.
My previous one was a Sonata, an older model that resembles the Sonata Designer physically but that had a 430w power supply.
There is a new sonata designer for 500w, and I liked these because they were super silent... but I doubt 500w will be safe enough given what I want, so I will check out these cases and power supplies.
Thanks all
By the way, is there any reason for me (no overclocking) to get any RAM besides the cheapest 800mhz from Kingston or Corsair? There are options like the following that are more expensive, but if it's all the same, I'll get whatever cheapest 2x2gb sets I can get. So my choice would be this one:
85$ - KINGSTON KVR 800MHZ DDR2 NO-ECC 4096MB KIT
other options:
119$ - CORSAIR 800MHZ DDR2 NO-ECC 4096MB TWINX C5
139$ - CORSAIR 800MHZ DDR2 NO-ECC 4096MB TWINX C5DH
169$ - CORSAIR 800MHZ DDR2 NO-ECC 4096MB TWINX DHX
115$ - KINGSTON HYPERX 800MHZ DDR2 NO-ECC 4096MB KIT
115$ - KINGSTON KVR 800MHZ DDR2 ECC 4096MB KIT
Since you're not overclocking, zero reason for you to get the higher priced RAM. Some of the higher priced RAM do have lower latency but you seriously won't notice the lower latency outside of synthetic benchmarks. So cheapest DDR2 800 RAM will be fine.
