Flashheart
- Nov 14, 2015
I havent built a pc for quite some time and Im looking to use an old atx case with dvd rom to build a new system for gaming. My budget has just grown as I had a bit of luck on the horses yesterday
I have these parts already...
http://uk.pcpartpicker.com/p/CcYRcf
Im not really up to scratch with pc components these days but I was thinking of taking back the ram as I got it from a local shop and swapping it for something faster. Are any of these better and are they compatible with the rest of the build?
https://uk.pcpartpicker.com/part/corsair-memory-cmy16gx3m2a2400c11a
https://uk.pcpartpicker.com/part/corsair-memory-cmy16gx3m2a2133c11
https://uk.pcpartpicker.com/part/corsair-memory-cmy16gx3m2a2400c11r
I take it the higher the frequency the faster the memory? So these 2400mhz are better than 2133mhz and the 1600mhz I might take back?
Then I was looking at putting in the i7 4790k
https://uk.pcpartpicker.com/part/intel-cpu-bx80646i74790k
and a gtx 970 although there are so many differant 970s im not sure which make to go for.
Then get windows 10
https://uk.pcpartpicker.com/part/microsoft-os-kw900139
Would these parts work together and run new games on max settings at 1080p?
Im in UK
The only purpose for the pc is gaming. I,d hope to run games on max settings for the next 3 years.
Then get windows 10
Im in UK
