Need help picking a video card!!!
SirKronan
Dear fellow [H] members,
(if you don't want the background info just skip to the question part.)
I have no idea what I'm going to do now. I joined this forum and started building my very first rig almost a year ago. It's been fun, and I've learned a lot, and had (at least I think I've had) a few good successes.
I started with an Abit IN9 32X Max 680i motherboard. It had SLI capability, and I threw in a 7600GT at first, then an 8800GT, then finally the 8800GTS (which I bought from EVGA in order to be able to step up later ... which I never did.)
The Abit board never could overclock my Q6700 beyond 3.33GHz, but was otherwise stable and overclocked memory well. I replaced it with a 680i from EVGA which overclocked my Q6700 100% stable to 3.65GHz, but temps were scary high. I upgraded from the 680i to a 780i also from EVGA. It wouldn't overclock my 6700 worth a CRAP, even with decent temps while using a TRUE with an amazing fan. It wasn't stable at all, even at stock, and fan control didn't work. I think it ruined one of my fans by overvolting it. Sounded like a jet engine, way louder than most fans normally sound even at 100%. Needless to say, EVGA was good on the support and RMA. The new board had fan control that worked flawlessly, and it at least overclocked my processor to 3.33GHz ... for a while. Then when stability started to suffer, I knocked it down to 3.2, then again to 3.0. Each time I had to downclock it because stability would start to suffer.
I wanted a better overclock on my Q6700. I wanted a rig that was more stable, and I was sick of nVidia chipsets. So I threw a 2.2GHz older Allendale on my $250 780i motherboard and used it in my wife's home office rig. I purchased the $120 Asus P5Q-Pro for my "mean machine." Most stable quad overclocker board I've ever used. I sold the 8800GTS to a friend and bought a 4850 (for the option of future crossfire.) I have been able to hit 4.0GHz windows stable. (very low vdroop compared to my previous nVidia's) I now run 24/7 settings at 3.6GHz with linked memory at 900MHz. Thing runs like a dream and temps are much more respectable. Never need more than 1.49v either. Vista is a LOT happier with this ASUS board.
I wanted more stability and a higher quad overclock because gaming isn't the most important thing for me anymore, but still VERY important. We recently purchased a Sony HD camcorder, and I have Pinnacle Studio. High def. editing and video encoding are now high priorities as well. I also like to rip and encode my DVD collection to my iPod, so the faster the processor the better, and the more stable I can make my system, the better.
Now that that's out of the way, time for the
QUESTION
What should I do about the video card situation? I have seen deals on the 9800GTX+ for $160 FS. I can also snag a 4850 to do crossfire for $140 after MIR. I can probably tweak the 780i to run my processor at 3.33GHz stable. And I also have a friend I might sell my 4850 to, as it is practically new, for $150 (he wouldn't have to send in rebates or anything, and I paid $190 for it - got it right after they came out.) Should I switch to the 9800GTX's on my nVidia platform, or just nab a second 4850 for Xfire?
Considerations:
My 4850 runs great, and performance is excellent, but in Supreme commander it hits like 90c and will occasionally shut itself off, even with all the fans in my case and on the card at 80-100%.
The 4850 has exceptional hardware acceleration for HD video encoding, rendering, etc., along with native HDMI support via the included adapter.
A second 4850 in crossfire will be an easy and economical performance boost.
My Q6700 runs a lot smoother and overclocks a lot easier and cooler on the solid P45 chipset.
The problem: Heat. With two 4850's heat worries me a LOT. I would have to (and am willing) to shell out about 80 bucks total for aftermarket coolers for both cards. The stock cooling is so poor that I will likely be able to overclock quite a bit and still be well under stock temps using the Arctic Cooling Twin Turbo (compatible with two 4850's in CF).
Stock cooling for the 9800GTX+ is superior and would allow overclocking out of the box.
I could do triple SLI with my 780i!!! (ROFL) :eek: (I joke. I joke.)
The problem: Q6700 overclocking. I actually like the memory overclocking options better in the 780i, but I'm more concerned with the quad overclocking and stability.
So what do you guys recommend??? 9800GTX+ in SLI on my 780i?? Or just get a second 4850 and some aftermarket cooling for CF on my current rock solid rig??? Thanks, in advance.
first off, 4850 crossfire = best bang for the buck. the 9800GTX+ are two close to the price point of the GTX260 to be worthwhile and you can dump the Nvidia board that is not working well. just sell it
second, you can adjust the fan speed on the 4850 using riva tuner, or new drivers allow fan control. no need for third party. just adjust the speeds if you don't like where they are
Tertiary the price on a 4850 is 130 to 140 AR now, buying a used one for 150 makes no sense at all.
I got my msi gtx260 oc for $197 on newegg at one point, It went back up to $239 now, but it does come with rainbow six vegas 2. I'd wait and see if it goes back down to $199.
QFT. Definitely the 4850CF and your current motherboard.
See if this guide helps you:
http://hardocp.com/article.html?art=MTU1MiwsLGhlbnRodXNpYXN0
Remember the heat issues though. Add $40 per card for aftermarket cooling. When I go crossfire that'll be an extra $80. So say I spent $150 for my first and $140 for my second after rebate. That makes a total of $370 by the time you add the aftermarket cooling. And there is a new barb in the mix I just found out about now.
Adobe CS4 supports GPU acceleration. So in Illustrator and Photoshop I would definitely have a productive edge with the nVidia setup vs. the ATI setup. I really don't know what to do now. The 9800GTX+ won't need any after market cooling, even when overclocked and in SLI.
But ATI on the other hand is probably slightly better for editing Hi Def video, even though nVidia has acceleration there as well.
I'm really torn. Thanks for your input thus far, guys. Any other ideas?
(p.s. I have fixed the fan settings on my 4850. Even at 80%, which is excruciatingly loud, it hits over 90c in Supreme commander. My case airflow is phenomenal, too. The things just get TOO HOT. People with aftermarket cooling are getting excellent results with these cards. I could even pick a second card that already has aftermarket cooling, too.)
If I might make a suggestion...
I recommend you stay with a single GPU solution.
I play SupCom, also. And with a GTX 260 Core 216, it runs smooth as butter everything maxed out with 8X AA @ 1680 x 1050.It will also run cooler than HD 4850 Crossfire. It has more VRAM (896 MB vs 512 MB) and with a decent overclock, it will run as fast as a stock 280.
I would stay away from 9800 GTX+ for the same reason I would stay away from HD 4850 Crossfire. There just isn't enough VRAM for higher resolutions and AA. I know [H] says otherwise, but I think you'd be disappointed with either of those set-ups in the long run.
I've had 9800 GTX SLI before and it was horrible. I got 16,000+ in 3DMark '06 with just a dual-core CPU, but Crysis play was flat-out terrible compared with what you would expect.
I found even a single HD 4870 better than SLI'd 9800s in actual game play.
You can find a GTX 280 for under $400 or a GTX 260 Core 216 for $280 or less. Either will fit your budget and I guarantee you'll be much happier.
You know, that seems like sage advice. Dan_D would be proud of you, pushing the single card cause ... :p
So how about this, guys: Sell my 4850 for w/e, and get one of the new 4870's with 1GB ram? That still leaves me with my incredible stability and good overclock I have now. Only thing I'll miss out on is GPU acceleration in photoshop 4. (it's not a big deal now as I only have CS3 anyways.) If I went nVidia right now, I would probably splurge for the new CS4 to get the acceleration. Truthfully, with the overclocked quad and 8GB of ram I have right now photoshop runs freaking good, so I don't know that it's monetarily worth it. And who's to say AMD won't drop some Photoshop acceleration some day, too.
So .... 4870 w/1 gig, or jump ship to nVidia?
I think the 1 GB HD 4870 is great choice. The HD 4870 should have always been a 1 GB card...
I'm just an anti-512 MB kinda guy for anything over a single HD 4850 in terms of performance.
More VRAM (and system RAM) is needed for today's games and apps IMO.
If you are considering it, I would go for the 4870 1GB.
If you are still looking into getting a second 4850, you definitely need some aftermarket cooling on those. You can get the Accelero S1 for about $25 each so that makes $50 for 2 of them + some fans.
SWEET. Thanks. That is very useful info. I had hoped not to have to take my main rig back to nVidia's inferior chipsets just for a gaming graphics card. Superior CS4 acceleration would have possibly been a push in that direction. To know that CS3 (which I legally have already) is already accelerated with the ATI cards is the icing on the cake. I don't really have any motivation to spend extra on CS4. I'll wait until Windows 7.
Yeah. With a 24" monitor and some of the newer games (especially like Supreme Commander) 1GB will give me a substantial boost over a 512 card. That's what I'm thinking anyways. [H]'s review loves the new 4870 with one gig. The cooling is SOOOOO much better than the stock cooler on the 4850.
Yeah, the S1's do really well, but to get them to work in crossfire I've read you need to do some significant twisting and bending to get things to fit.
Thanks a bunch for the info. I'm leaning towards the 4870 big time now. MSI has one on sale at the Egg that's $270 after a mail in rebate, and comes with that free rainbow game Newegg keeps giving away. It's butt-ugly though.... I might wait for a sale on a non-fugly card.
Feel free to share any more insight!
You can get a single 4850 with 1GB VRAM also.
My problems with the 4850 are the temps. I would have to buy one with aftermarket cooling, or put aftermarket cooling on it after I received it.
Right now I'm kind of waiting to see what the 4850x2 brings to the table. If it has a $300-350 price tag (giving you basically two 4850's in CF on any motherboard) that will be a steal.
I think ATI is holding off on releasing it because they want to sell as many 4870's and 4870's with 1 gig as possible. Just a theory. The 4870 will take a serious hit if the 4850x2 performs well and has a competitive price.
Imagine a $350 card that could beat a GTX280.... Two 4850's in CF will beat a 280 in many new games.
If there is a game available now that you need the extra frames per second then I would recommend the second 4850. As for cooling I would tweak the the fan settings, I have had success with it. Or pick up an aftermarket cooler, which can definitely help. If there isn't a game that warrants a new card I would pick some good 120mm fans and a roomy case (if you don't have one) that would reduce the heat issue when you do need to upgrade.
I always try to state that you don't upgrade for the sake of upgrading. Upgrade cause you want the best playability for the games that you are playing now. Sometimes even the best current gen hardware can't play the title you want. So I recommend putting off playing until the hardware catches up.
Two 4850's in CrossFire is a deadly combination. Probably not as good as the 2GB 4870 but much cheaper.
Yeah. I really want to see how well the 4850X2 does, and how it's priced. That would open up the door to future quad crossfire, although I'd probably never do that. Two 4850's in CF would be fantastic on my 24" monitor. Would run most games maxxed. At the very least when the 4850X2 comes out, prices on 4870's - 1 gig and 512 - will most assuredly drop.
Yes, prices would drop but demand for those cards would also probably increase so the price drop might not sustain itself and retailers may be running low on supply.
When is the 4850X2 supposed to come out?
looks like it'll come out within weeks... So I've heard... More interesting is that it's rumored to come out at $350-$400!!! A single card (sort of) that matches - and sometimes beats - a 280 for $350. HOLY CRAP.
Now what do I do? They are supposed to be the one gig 4850's in the x2. Two 4850s in CF beat a single 4870. Is it worth it to wait and spend the extra on the 4850x2? I wonder what kinds of heat issues it will have.
call ATi and tell them to hurry it up already with the 4850x2s, if they say it'll be a while, then you should go ahead and either swap your 4850 for a 4870, or get another 4850, and crank the fans up manually with Rivatuner to 110%. personally I would get the extra 4850 crossfire them up and crank the fans,
UNLESS someone in here knows that the 4850x2 is coming out soon (2-4 weeks).
You know you don't have to have the same model 4850 to crossfire it right? You can have a 4870 crossfire with a 4850 from different brand with different cooling solutions.
I think that's incorrect, unless they've changed things. I think that ATI will let you crossfire a 3870 with a 4870, but not a 4850 with a 3870 or a 4870. I believe you can CF a 4850 with a 3850 though ....
I may be wrong. Maybe that's different with the newer drivers now. Have to check...
Should be 2-4 weeks, but that's just rumor right now. ATI really did say "Within weeks it'll be on shelves" or something like that.
OK!!! How about the new 216 core 260?? BFG's got it for $270 shipped after rebate + Farcry 2 free + 3DMark Vantage + A corny flashlight ..... FOR $270!!!!
Is this not a way better deal than the 4870 1GB right now?? I'm getting ready to put in my credit card number ... any reason why I shouldn't? BFG even has step-up now like EVGA.
