NEED HELP (PC driving me crazy)
Slickgreen
Ok
For about the past month my PC has just been shutting down
I mean hard..
Ill be playing a Game (shutdown)
Downloading (SHUTDOWN)
anything>
Ive tried to narrow it down to something but cant
ive ran virus scan nothing...
Pop ups none
Ok so you are problably saying Replace the Power-Supply
i did still does it>?
What gives could the OS be doing this?
any Ideas
Please HELP
im going nutz
When PCs over-heat, they shut down to prevent damage. Make sure you CPU and system temps are okay.
Thanks for some of the help guys
I have checked my systems temp and it stays around 39C
is that normal?
I am running a a stick of 512 pc3200
SO i wonder if its the RAM
dont think so
I havent re-install and did a fresh install since i first installed?
could that be cuaseing any problems?
ANYMORE IDEAS?
