Hornet
- Oct 4, 2005
Hi, I need some advise/opinion on these matter
1. Which of the following type of heatsink for RAM is better?
I'm using KVR DDR400 ram BTW....ramsink or heatspreader is better in terms of cooling performance? both are at the same price.
2. Does the waranty sticker need to be removed? I'm worried I might cause static charge damage to the ram with my hands rubbing agains it. Is there any safe way if need to?
Thanks alot for any comments
