If you're gonna ask us to build/list a PC for you or seek advice about a build, please answer all of the following questions:
Mostly for web browsing and some heavy duty applications very little if any gaming.
$500 before tax and shipping
3) Where do you live?
North Carolina
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I need a dual core processor to run heavy duty programs simultaneously and be capable of running two 24 inch monitors
Possibly be able to reuse OS
6) Will you be overclocking?
No
24 inch
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I need to be able to run two monitors and heavy duty programs with little problems
10) Do you already have a legit and reusable/transferable OS key/license?
Possibly
Here is what I came up with already.
Rosewill R6426-P ATX Mid Tower
Western Digital Caviar SE WD800AAJS 80GB 7200RPM SATA 3
ASRock A780GXE/128 AM2+/AM2 AMD 780G ATX AMD Motherboard
LG Black bezel SATA DVD-Rom Drive Model
Rosewill RP500-2 500 W ATX12v v2.01 Power supply
Rendition by Crucial 2 gb 240 pin DDR2 667 PC25300
AMD Athlon X2 Brisbane 2.1 GHz Socket AM2 45W Dual Core Processor
I'm not exactly up to date on all the latest subtle differences in components so my big concern is if the parts match properly. Also I'll be using two monitors and I'm not sure if this configuration will let me do it. Please let me know thanks in advance!
Wtiberon
North Carolina
No
24 inch
ASAP
Possibly
Wtiberon
