Need help on *BUDGET* build
delerium
First off, i want to thank you for taking a look at this thread.
I have been *building* this custom pc for about 2 yrs now. No job, and only saving money from mowing lawns, xmas, bday money. When i first got into pc hardware 2 yrs ago, 939 was the way to go, thats all iwanted, end of story. I shortly moved back to dirtbiking, airsoft, and other hobbies that i always had spent my money on before thinking of the new pc.
Well now i have around $330 to spend and need advice if i should stick iwth the 939, or go am2 x2.
I currently have:
Antec super lan boy case
thermaltake 420w psu (24pin)
evga 7600gt pcie
i am wanting to buy this within the next couple of days, so i want your opinion on which setup to go.
939 setup:
seagate barracuda 80gb sata HD
MSI K8N Neo-4F
Sony Black IDE DVD Drive
OCZ Performance Series 1GB Ram
AMD Athlon 64 San Diego 4000
Zalmon 92mm HSF
AM2 Setup:
same hd
same dvd drive
Abit KN9 Mobo
Geil DDR2 800 1gb Ram
Now im stumped on which cpu to get...
amd athlon 64 x2 3600 Brisbane w/ that zalmon hsf
amd athlon 64 x2 4600 Windsor retail
or amd athlon 64 x2 4000 brisbane retail
Please help me out with this build, whether i should go foor the am2 and upgrade later on with just more am2 parts, or go with the faster? 939 for now, and upgrade completely later on.
Since you are on a limited budget and Socket 939 is pretty dead at this point, go for the AM2. Oh and always go for the Brisbane AM2 CPUs. They draw only 65W which may make them better overclockers.
Wait till April 9th to order AM2 CPUs. Supposedly AMD is cutting prices on its CPUs. So you can buy that retail version of the 3600+ Brisbane for only $69 or the 4400+ Brisbane retail for $115.
Oh and you might want to read this link about AMD VS. Intel CPUs based on their respective price cuts.
http://www.xbitlabs.com/articles/cpu/display/dualcore-roundup.html
Wow, thank you so much Danny for that link. It really opened my eyes to dual core cpu's.
After researching some more, ive found lots of ppl posting cpu-z verified screenies of getting 2.75-3.0... O.O
I remember when a 2.4 athlon 64 was a goal for oc'ing and it was comparable to the p4's 3.0 range.
Ive definately decided to go with the am2 setup now. Im going to wait till the price drop, and maybe even try and find a cheaper OEM version of the 3600 Brisbane, and a good HSF for some OC'ing.
Would that RAM be good for OC'ing? i dont think i need 2gb now, as im mostly going to be playing games like cs, css, ro.
Another concern i saw from someone on the net was that the Abit KN9 board isnt good for the Brisbanes because of the low core on the cpu, and the mobo makes it to hot? Anyone heard about this issue? Ill try to research a bit more and see if it was just bs, or if its a legit concern.
Thanks again guys, and for what its worth, anythings going to be better than this current pc. p3 500mhz, 128mb ram, 8mb riva tnt, 18gb fireball hd xD
EDIT-----
Well ive been checkign out the AM2 mobos at newegg, sorting from lowest price xD
Whats a good northbridge i wanna get? back in the day nf4 ultras were the best, but now i know there old technology. are the nvidia 550's any good? anyone wanna reccomentd a good mobo for around $75 should i stay away from the amd, ati and geforce series mobos?
edit2---
what about the biostar tforce550? seems this is a pretty good board. Is nvidia 550mcp a better chip than the nf4ultra?
a 3600+ brisbane and a biostar tforce550 would be a great budget combo. there's a thread in the amd mobo forum with guys hitting close to 3.0ghz with this combo. as for a heatsink i would try to go with a tuniq tower or thermalright ultra 120 if you want the best aircooling.
No idea. Hit up the Memory forum here for advice about that,
It's actually a pretty decent board according to a few people here on the forum. You may want to hit up the Motherboard forum for more info about the TForce550.
If you're looking to overclock, go for one with an F3 stepping. Head here, and in the stepping drop-down box select "F3." Then copy-paste the OPN for either boxed or tray processor into Newegg (they don't stock many of the low-end models anymore) or into google (nextag works well for this) to show you places to buy your chip.
There is a low-end x2 3800+ on an F3 stepping, which would not only help you out with a higher multiplier than the x2 3600 (10 vs. 9.5), but it would also help because of the maturity of the 90nm process and whatever the hell AMD did to the F3 revision silicon. While the X2 3600 clocks decently well, the 65nm process isn't very mature yet; so we're seeing ~3ish MAX out of the chips, while many of them don't quite reach 3. Meanwhile F3 stepping chips are easily hitting 3 (oftentimes at or around stock voltage), usually maxing in the 3.1-3.4 range. Most importantly, they also don't require some kind of cherry-picking in terms of their production week or anything else; they're all good clockers. Check out Eclipse's review of the 4000+ F3 (single core) here.
Here is the chart he made about how it scaled with voltage (stock is 2.6ghz @ 1.25v):
However, if all you're looking for is the cheapest possible system, then the 3600+ x2 is it. If you pair it with that Biostar TForce motherboard (and update the bios) it supposedly reaches some decent HTT speeds.
