you are correct on the revE part, but to tell the difference in E4 and E6, you gotta look at the first line. BV = E4 (manchester), CD = E6 (toledo)MJCfromCT said:Thanks for the reply,
I would download CPU-Z if the rest of the computer was built at this time
With regard to the stepping, I was familiar with steppings denoted as "E4" or "E6", etc...what does CDBHE translate to? Also, am I to assume that this is a revision E chip since it is CDBHE?
Manufactured in the 27th week of 2005 if I am not mistaken.0527
