Hi all,
My HTPC is running a bit hot, so I'm here for some advice to see if I can get it to run cooler without making more noise.
My CPU is an Intel E5400 on a Zotac 9300 motherboard. Everything is fitted inside an OrigenAE M10 case with the Intel stock cooler. Theres a 60 mm case fan too, but I've been trying to undervolt and underclock the CPU (using RMClock), so it can run without the case fan because it's pretty noisy.
I've never done any overclocking or such, so I do not know much about temperatures, CPU volts and clocks. Please keep this in mind when writing your answers
I've made some measures, with the case fan:
CPU fan speed: 50% (higher speeds will result in too much noise)
Case fan speed: 100% (way too much noise, can't control it's speed)
FID: 10.0x (~2000 mhz)
VID: 1.1V (default is 1.2875V)
Temperature after full load in 7 mins: 59 C
And without the case fan:
CPU fan speed: 50%
FID: 10.0x
Temperature after full load in 15 mins: 78 C
And idle temperature:
CPU fan speed: 50%
FID: 6.0x
VID: 1.1V
Temperature after idle in 15 mins: 63 C
What do you think about these temperatures? Are they way too high, or is it normal? How high can they be before I should start to worry?
What else can I do to lower the temperature? I would not like to go much lower than ~2 Ghz. Maybe an VID lower than 1.1V would work? But how can I do that? RMClock only allows me to go as low as 1.1V and I haven't had any BSOD yet.
Please give me some advice and suggestions on what to try, otherwise I'll have to see if it's possible to find a low noise 60 mm fan.
I hope you can help me. Thanks in advance!
CPU fan speed: 50%
FID: 10.0x
CPU fan speed: 50%
FID: 6.0x
VID: 1.1V
