Need help fixing my wife's laptop screen
Discussion in 'Mobile Computing' started by cdr_74_premium, Dec 25, 2017.
  1. cdr_74_premium
    cdr_74_premium [H]ard|Gawd
    1,583
    Oct 20, 2010
    My wife's laptop screen started to act weird a while ago. I hope I can explain it, but anyway, if that's not enough I will make a video of it.
    Sometimes, the picture gets messed up, and you have to open/close the lid a little bit until finding a spot in which the picture is clear as it should.
    How do I fix that? The laptop is an ASUS X202E, and works fine other than that.
    Thanks!
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    10,624
    Oct 7, 2000
  3. Batboy88
    Batboy88 Limp Gawd
    326
    Dec 25, 2017
    Hahaha, looks like on there, need help fixing my wife.....there's something wrong with em man Lol.
    Nah I don't know man..same thing like dead pixels on a monitor/screen have to send it back to em.
  4. jimh425
    jimh425 Gawd
    645
    Jan 7, 2012
    There are lots of parts for that laptop on ebay. If she doesn't use the touchscreen, try disabling the USB connection to it. Unfortunately, Windows turns it back on. BTW, one of the two that we have has the same issue.
  5. stealthballer123
    stealthballer123 Limp Gawd
    282
    Mar 2, 2017
    cord is loose/possibly nicked a trace.
    replace the ribbon cable, its' not too hard, just tiny, hope you have good eyes/not that meaty fingers
  6. Greg Watson
    Greg Watson [H]Lite
    98
    Jul 30, 2018
    Definitely sounds like a cable issue. Have fun replacing that. I always have a great time trying to get the wires threaded through the hinges of laptops.
