Need Help finding PSU->UPS Power Cord
yogiB
Where can I purchase, online, a power cord to connect my PSU to my UPS?
My UPS accepts only connectors that are the SAME type (but MALE) as the ones accepted by PSUs. In other words, I need a cord, which has on one side the PSU connector (FEMALE) and, on the other side, the MALE of that PSU connector. :eek:
Hope I wasn't too confusing. Where can I find these online? If I'm to search for them, what do I call these types of cords?
Thanks a lot for any ideas.
I would think that would be called an extension cord of some sort, as that's what it seems to be. Also, I know that cords like that used to be used on old PSUs to power the monitor from the PSU, as they used to have that type of connector on the back. Good luck!
IEC C13 (female) \ C14 (male)
http://www.iec.ch/
http://www.accesscomms.com.au/iec320.htm
http://www.google.com/search?hl=en&q=+IEC+C13++C14&btnG=Google+Search
http://www.stayonline.com/c14_iec_cables/index.asp (upto 13 foot)
I havent bought from stayonline
and Im not sure of the length youd need
just thought Id throw in that return
Good Luck ;)
APC rackmount power distribution strips use these cords, i have a bunch of them in my rack, but those are rated for like 15A each so they are super thick hehe
