Hey guys I had a quick question regarding my PS/2 keyboard not working on initial boot up.
I just finished by new build, turned the computer on and get a screen on the monitor with an ABIT logo that says:
'press tab to show POST press DEL to enter setup'
Now the problem is that my keyboard doesn't work! Here's what I've tried so far..
I took the keyboard and hooked it up to another computer and it works fine there, so the keyboard isn't faulty..
I got a PS/2 to USB converter and hooked the keyboard up to that to see if a USB connection would work but still doesn't.
I tried using a completely different keyboard as-well and it also doesn't work.
Is it safe to say that my motherboard is broken? When I start it up it gives me the 1 beep so I assumed it was working properly. This is my first build that I've ever put together so forgive me if it's something really simple that I just am not thinking of..
Here's my hardware...
ABIT IP35-E Motherboard
Intel 8400 3.0ghz 45nm
8800 GT
2GB Ballistics
550 W Cosair
8800 GT
2GB Ballistics
550 W Cosair
