Need Help Determining Computer Build for a Friend
Ethari
High-End Gaming
$1500-$2000
Cleveland, OH
Case
12+ GB RAM
Intel Quad Core
1200 W Modular PSU
Graphics Card
Motherboard
Wireless Card
1 TB worth of storage
1 SSD
~22' IPS Monitor
N/A.
6) Will you be overclocking?
No
Don’t currently have one, but usually set it at 1920x1080.
A.S.A.P.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Several USB Ports
SATA 6GB
Capacity for upgrade
Crossfire/SLI
Windows 7 64-bit
Looking for some help for determining a build for my friend. He’s recently started into pc gaming and is looking at building a rig that will play most games with high fps (Specifically FFXIV, and most likely some FPS). Looking to build ASAP. As always, I appreciate all of your guys’ help and thank you in advance.
Here's what I recommend:
$190 - Intel Core i5-2400 CPU
$140 - MSI Z77A-G45 INtel Z77 ATX Motherboard
$96 - 2 x G.Skill Sniper F3-12800CL9D-8GBSR 2 x 4GB DDR3 1600 RAM
$488 - Gigabyte GV-R797D5-3GD-B Radeon HD 7970 3GB PCI-E Video Card
$160 - Crucial M4 CT128M4SSD2 2.5" 128GB SSD
$110 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$181 - Corsair HX850 850W Modular PSU
Total: $1365 plus tax and shopping.
You're on your own for the monitor and wireless card. As for the case, I recommend the following cases:
$100 - Corsair Carbide Series 400R ATX Case
$100 - Lian Li PC-7B Plus II ATX Case
$118 - Corsair Carbide Series 500R ATX Case
$120 - Fractal Design Define R3 Arctic White ATX Case
$120 - Fractal Design Define R3 Silver Arrow ATX Case
$125 - Fractal Design Define R3 Black Pearl ATX Case
$120 - Lian Li PC-9F ATX Case
$120 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$130 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$130 - NZXT Phantom PHAN-002OR Black Finish w/Orange Trim Full Tower ATX Case
$140 - Antec P280 ATX Case
$140 - Antec Performance One Series P183 V3 ATX Case
$140 - Corsair Obsidian Series 550D ATX Case
$144 - Silverstone RV03B-WA ATX case
$150 - Silverstone TJ04B-EW ATX Case
$160 - Corsair Graphite Series 600TM ATX Case
$160 - Silverstone RV02B-W ATX case
$164 - Corsair Special Edition White Graphite Series 600T ATX Case
$178 - Silverstone RV02B-EW ATX case
$170 - Corsair Obsidian Series 650D ATX Case
$220 - Silverstone FT02S-W ATX Case
$230 - Silverstone FT02B ATX Case
$270 - Corsair Obsidian Series 800D CC800DW Full Tower ATX Case
