need help deciding on MOBO+cpu upgrade (amd)!
EviL-aLphA
hey guys, i think its about time to upgrade my system, but with all the new hardware out im kind of confused, im used to just getting the latest and greatest nForce board, but i guess now there are amd made chipsets and such.. (i havent really been keeping up to date with mobos)...
im looking for the newer generation and i cant really seem to figure out whats the best
im assuming that 790GX is the latest n greatest, how does it compare to the latest nforce (nforce even worth it anymore nowadaze)?
im planning on upgrading to a 6000 or higher cpu (maybe phenom)
im looking to spend about 300 max for mobo and cpu..
than spend a bit later for 4gigs of ram etc
ive been looking at these boards, but i can careless for integrated graphics etc because i plan on upgrading my gcard soon too
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131331
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128352
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130190
theres this combo going right now,
http://promotions.newegg.com/AMD/Ph...mmc=EMC-IGNEFL090208-_-MECH-_-EB5-_-AMDbanner
this is my current set up
windows vista 64bit
asus a8n-e
amd 64bit 4800+ x2 (939)
nvidia geforce 8800gts 312mb
2 gig of corsair xms 3200 ram
creative audigy 2zs
any suggestions?
thanks!
You do know that you have to replace the RAM as well right? Since AM2 CPUs don't support DDR RAM and all that. So what would be your total budget right now for the RAM, mobo and CPU? Still $300?
yeah im aware of that, im planning on selling my current set up..
so probably around 400 total give or take
evil-alpha...definitely checkout ANANDTECH.COM they paired and tested the 790fx chipset with some phenom proc including the 140w quad-core 9950
Hmm, you can get an Intel build for $400:
Intel Core 2 Quad Q6600 CPU - $190
Gigabyte GA-EP45-DS3R Intel P45 Motherboard - $130
G.Skill F2-6400CL5D-4GBPQ 2 x 2GB DDR2 800 RAM - $70
Total: $390 plus tax and shipping.
A Q6600 would murder most Phenom CPUs at stock speeds. OC it and it'll wipe the floor with Phenom CPUs. Though if you can only get $300, I recommend this set:
Intel Core 2 Duo E7200 CPU - $120
Gigabyte GA-EP43-DS3L Intel P43 Motherboard - $85
Total: $275 plus tax and shipping
The E7200 would still beat the X2 6000+ and some Phenom CPUs.
But if you want to stick with AMD, yes the 790GX is the chipset to go with for AMD CPUs. It's on par with Nvidia chipsets for AMD CPUs now. As for which mobo to go for, that Gigabyte motherboard you linked to got a decent review here at the [H].
If you really wanted to, you could get the Phenom 9600/TFORCE TA790GX combo, 4GB of DDR2 800 RAM, and the 8800GT video card (which is better than the 8800GTS you currently have) for around $400:
$209 - AMD Phenom 9600 and BIOSTAR TFORCE TA790GX combo deal
$70 - G.Skill 2x2GB DDR2 800 dual channel kit (free shipping)
$111 - PNY 8800GT (free shipping)
$390 - Subtotal (not including shipping, taxes, or rebates)
Of course, if you're playing games on a 22 inch or larger monitor, you should definitely consider a better video card (like the AMD/ATI HD 4-series).
But Danny's right: An Intel build would be more powerful.
i second an INTEL build 45nm
I have a few questions (to help move things along):
- Which monitor/resolution are you using?
- Which games are you (planning on) playing?
- What other tasks (besides gaming) are you going to use your computer for?
- Which features do you want on the motherboard?
So there's no confusion, my earlier comments were an attempt to give you some options to consider (though, truthfully, I would recommend an Intel-based build as much as the others). You may not need the "latest and greatest" AMD (or Intel) build if your primary concern is going to be gaming.
im using a samsung syncmaster 1100df 21" screen currently at 1600x1200 resolution
- i play hl2 a lot, some crysis, planning on playing any next gen high end game that comes out (alan wake etc)
- i do a lot of music listening (almost always playing music), i do a good amount of audio ripping/encoding, i view movies from time to time, play games here and there when i have the time, do a heavy amount of downloading/dealing with RAR files etc, and school work (word/powerpoint etc).
- all basic features on the motherboard, i can careless for integrated video/sound, i also dont care for any more than 1 PCI-E slot, atleast 4gigs of ram support, all around good features such as sata2 and such
i really havent had an intel since about intel pentium 3 back in like 2000, had amd since so im totaly clueless about intel nowadaze
any more suggestions would be more than welcome!
thanks
Performance-wise, one of Danny's builds would be better for you with your budget, as Intel today beats AMD on nearly everything except price.
Again, I recommend one of the AMD/ATI video cards...get the HD4850 if you want to spend as little as possible, or the HD4870 if you consider yourself a serious gamer.
Onboard sound has now progressed to the point where it's good enough for most users. Try the onboard sound first, and then consider a discrete sound card if you're otherwise disappointed.
Is there anything (else) you were going to transfer over from your current build?
so far as of now im transferring my 8800gts which satisfies me as is for the moment, once i cash in a couple of more paychecks and actualy update my processor n mobo ill be upping my graphic card probably to a 4850 or 870 if the price is right, i used to be amd/ati all the way, till i got a great deal on a 7800gtx and on a 8800gts, so id love going back to ati cuz they rock all around!
im also going to be putting my 500 gig sata 2 and 320gig sata2 hard drives and my audigy2 zs sound card.. as of now thats all i really got to put into a new system.
how well would the 300$ intel platform perform compared to my x2 4800 and asus a8n-e ?
i am considering intel as it is looking a bit tempting, its just that i havent used an intel in ages
thank you
The newer technology used in the Intel Core 2 series processors makes even the low-end E2180 perform faster than your S939 X2 4800+. The E7200 that Danny mentioned earlier is (IIRC) faster at stock speeds than the AM2 X2 6000+ (and it has a higher overclocking threshold).
Again, go Intel; but go with whichever setup you could afford. (Both will allow you to use 4GB of RAM right away.)
It will be good enough for your needs. Save your extra money for a new video card -- it will show a more noticeable improvement in gameplay.
ok, thanks a lot! i will update once i purchase and set it up ;)
cant wait to see how it compares to my 4800 and 2 gigs of ram on vista 64 with all the multitasking and such :)
