need help deciding between 2 mohterboards.
Master_shake_
they are basically the same board.
are you in to RGB leds? get the MSI.
do you need usb 3.1? get the MSI
i am also certain both have a 3 year warranty.
THUMPer
I think either would be fine.
I would personally go with the MSI. I've had great luck with them, including a couple RMA's that went smoothly.
