rampantandroid
- Jun 14, 2006
So...my system now reboots randomly...
-sometimes at boot up, sometimes after it's been running for a while.
-If it's been running for a while, sometimes I just get a hardlocked screen (no HD access, same screen displayed, the mouse does nothing...the keyboard does nothing)
-Sometimes at boot I just get a black screen (my monitor goes into power save, as it has no input) - in this case, the keyboard has no power - the backlight and the numpad light go out
-Sometimes I just get to the welcome screen...and I reboot all the way to POST and get this message afterwards:
And every boot, I get these (one for each processor Windows sees, which is 8, though I have 4 physical cores):
-I've tried a new powersupply and it did not help
-I'm on a new videocard (my 5970 no longer outputs any DVI, so I moved to a GTX280)
-Since this started RIGHT after I replaced my 5970, I also tried an ancient S3 Savage 4 Pro PCI card...and immediatly got rebooted
-I ran memtest86+ for a little bit and saw nothing, but I moved to my Crucial memory I had lying around - with this I temporaryily seem stable - we'll see as I keep browsing.
I also reinstalled windows, which didn't help any.
Now, could this be my memory? It doesn't seem like memory would cause me to go from the welcome screen...to POST. Is this my motherboard being flakey?
I ask because if it's my mobo, I'm just going to drive to Fry's tomorrow and buy a new motherboard and deal with mine later.
Thanks!
RA
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Performance power management features on processor 5 in group 0 are disabled due to a firmware problem. Check with the computer manufacturer for updated firmware.
Thanks!
RA
