need help chosing a motherboard
sandman92
i want to buy a motherboard thats alright
my budget for the mother board is $65
i wanted to get the Biostar MCP6P-M2 but i wanted to know if the there is better ones for my price range
well, considering your budget you will not have much choice. so if you read thats a good one, go for it. so why did you decide to go for broke on this one?
I can understand a tight budget but really that is not a good board. that is an OEMs "lets see how much we can cut our cost board". There is a reason that you see it with combo deals or bundles all the time, its damn cheap. Unless you want integrated graphics there are other low cost boards that might serve you better.
What are you planning to do with your PC and what is the budget. that would help use a lot.
that is about half the info needed. what is the budget? what games? if your content with on board sound and graphics there are some pretty cheap motherboards that will do some limited gaming, mainly older games or games at low resolutions.
my budget right now is around $200 to get a motherboard a hard drive and a dvd burner
i want to play company of heroes and later get a video card so i could play crysis
does that mean you have the ram, case, PSU, and CPU already? if so then its doable. otherwise your going to have issues
yea i just got a amd athlon 64 le-1600 2.2ghz is that going give me any trouble because its single core
Just out of curiosity when and where did you get your cpu? I personally wouldn't pick a CPU before getting a mobo. I am assuming you got it from an old computer since you can hardly find those in the store now days, why bother taking a very old chip and build a 'new' computer around it. Also note the cheaper the material, the harder for you to learn how to build a new computer. Plus by the time of your second build, technology will be completely different.
My humble advice is if you have a working computer already, stick with it, buy more expansive mainstream parts when you feel time is right, buying cheap parts is like throwing money in the garbage can.
i got it from newegg like two weeks ago when they were still selling it. i just want to get a mobo that could use this cpu and AMD Athlon X2 so i could later upgrade
yes and no, your not going to play crysis on it, or anything like bioshock. some of the older games will be fine. If all you have is the CPU your still going to have to buy the ram, power supply, motherboard, case, and hard disk. you can get a motherboard like this one http://www.newegg.com/Product/Product.aspx?Item=N82E16813135075
for about 60 buck after the rebate.
but the advice above is good, if you don't have a lot of spare parts laying around your going to have buy a new case http://www.newegg.com/Product/Product.aspx?Item=N82E16811147019 36 dollars, 44 dollars for hard drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
and 40 dollars for the memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820178154
the problem is that i got a amd athlon 64 le-1600 2.2ghz and i dont think its compatible
wow i recently purchase the case u recomended me like 3 weeks ago
I'm not recommending that case, I was just trying to show you what you could get. I recomend getting a bigger budget. everything I showed you will work though, if your running Linux as your budget doesn't include a new OS from microsoft
what I listed will run you around 200 with shipping, it will work, maybe, but not well. for a little more money you could build a much better system,
i already got a copy of linux but my brother was going to help me by buying vista for me
last post here, THAT WILL NOT RUN VISTA. Sorry but your going to need to do some reading up here. vista would require at least a dual core CPU and and a couple of gigs of ram. really 3gbs or so.
Unless light gaming you mean 2D games, onboard video will not cut it for Company of Heroes. Maybe a few Source games at 800x600 at low settings will be doable but certainly not Company of Heroes.
For light gaming, the AMD Athlon 64 LE-1600 is a bad buy. For basic web browsing, word processing, it's fine. Now what EXACT parts do you have in your hands right now? Please be as specific as possible about the parts you've already bought. Speed, price, model number, etc.
Company of Heroes is a bitch when it comes to requirement, my old 7800GT SLi can barely run it at 1920x1200 mostly low settings, onboard = slideshow, or the installer won't even let you install.
Low budget should look for dell deals buying parts + shipping and everything is not cheap.
not as part of this thread any longer but I was surprised at what the 780G chip set could do, really I don't think it good for more then old games (kids games and the like) but take a look, its the best IG I have seen. nice.
http://www.tomshardware.com/reviews/amd-780g-chipset,1785-10.html
well i got the cpu i mentioned and also http://www.newegg.com/Product/Product.aspx?Item=N82E16811147019 as my case and psu and going to get 2 gigs of ram for the mobo i end up getting from my cuzin.
i am not going to stick with that cpu in about 2 months i am going to buy a oem cpu may be the AMD Athlon 64 X2 4600+ Windsor 2.4GHz and going to get a video card thinking of getting the xfx 8500 gt 512mb of ram or the XFX PVT84JYAJG GeForce 8600 GT 512MB 128-bit
