Need help building one for gaming
sojumk
I haven't been in the PC seen for the past 5 yrs. Using apple due to what ia study. I have no idea what's what now...
I need someone's help with parts. Main reason is to play WoW in full setting and SC2. I already have a 22LCD screen or a HDMI 32" LCD/TV screen i can use.
Already have a "SILVERSTONE Sugo SG01-BF Black Aluminum / Steel MicroATX Desktop Computer Case" which i used it like 5 yrs ago. My budget is arund $500~$600.
I need graphic card,mobo,cpu,ram.
Might I suggest checking out Newegg?
If you want to build a nice budget gaming rig, I'd go with AMD. Decent performance and I decent price.
3) Where do you live?
6) Will you be overclocking?
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
-In the US
-This is the power supply that is sitting in the silverstone, however i don't mind buying a new one if that powersupply isn't sufficient.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817190012
-No
-Sooner the better
-Nothing fancy, something simple
$145 - AMD Phenom II X4 955 Black Edition CPU
$65 - Biostar TA880GB+ AMD 880G mATX Motherboard
$50 - G.Skill F3-10600CL9D-4GBNT 2 x 2GB DDR3 1333 RAM
$185 - Gigabyte GV-N460OC-1GI GeForce GTX 460 1GB PCI-E Video Card
$59 - Antec NEO ECO 520C 520W PSU
Total: $514 plus tax and shipping
-In the US
-No
-Sooner the better
1. Where in the US do you live? Depending on your location, you may have a fry's or microcenter near you to get some great deals.
2. I think a new PSU would be good to have. That one has 75% efficiency and based on what I read, it runs fairly warm.
But a basic build using newegg...
Core i3 550 + GIGABYTE GA-H55M-USB3 $207
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.572877
Radeon HD 6850 $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161348
2x2GB DDR1333 Mushkin ram $43
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146748
Antec NeoEco 520W $55
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371030
Depends on what you want to do, if you have a microcenter near you, you could get the x4 640 combo for $99. Depends on how much you want to spend for certain performance.
