Need Help building computer with 900$$*******
urbanlegend786
hey, my friend wants me to build him gaming computer, the budget is 900$ with a 17" LCD screen and i already have the case,an antec sonata without a psu, i am using only AMD and i have bad luck with processor's and since this isnt my money or computer i cant take chances so i was thinking of getting like a prebuild combo type thing were the proccessor is already installed to the MOBO, the computer needs to be better then this(well just most of the parts):
http://www.cyberpowersystem.com/system/ultra7500.asp?v=d
i was thinking of something like this:
1)http://www.newegg.com/product/product.asp?item=N82E16813131524
2)http://www.newegg.com/product/product.asp?item=N82E16814130214
3)http://www.newegg.com/product/product.asp?item=N82E16817153023
4)http://www.newegg.com/product/product.asp?item=N82E16819103535
5)http://www.newegg.com/product/product.asp?item=N82E16820220037
6)http://www.newegg.com/product/product.asp?item=N82E16822145088
7)http://www.newegg.com/product/product.asp?item=N82E16824116357
8)http://www.newegg.com/product/product.asp?item=N82E16827129164
i would also appreciate if you could find the same stuff for cheaper, thanks alot
Avoid Thermaltake power supplies.
6800GS > 6600GT
The Hitachi drive is just OK, I suggest the new Maxtor drives with 16MB of cache. They are only $10 more. I know the Hitachi has SATA 3.0Gbps, but the extra cache gets you a lot more more speed then the bigger bus does.
Monarch Computers assembles cpu, mobo, ram and tests them for a small fee.
Monarch
Just look in the combo's section.
Be sure to get a antec or enermax psu, and a 6800GS. 7800GT if you got the money. Get a maxtor 16 MB sata like said before. Rest looks fine.
