Need Help Building a Pc
copo172
Hey all,
I need help building a PC. I want to use the PC for multitasking and gaming (but not hardcore). I would like to keep the PC as cool as possible.
I will be using this pc for gaming, programming, and multitasking.
My budget is $1200 after taxes. I Can go slightly over budget if needed
3) Where do you live?
New York
4) What exact parts do you need for that budget? CPU, RAM, case, etc.
Everything, except a mouse, keyboard, and windows 7.
5) If reusing any parts, what parts will you be reusing?
6) Will you be overclocking?
Maybe in the future
I have on old 19" LCD, but I plan to purchase a 23"
On Wednesday, March 2 (tomorrow)
9) What features do you need in a motherboard?
Honestly, I don't know.
Windows 7, 64 bit
Thanks in advanced.
Can you provide some details on the kinds of games you play as well as the types of programming you do? Notably if you plan to be doing some large compiles of code or rendering/processing large amounts of data (on the gigabyte scale, etc)
On another note, it might be good to hold off for a bit. There's still some blowback from the Intel recalls so the market is kinda weird at the moment.
I mainly play shooters and strategy games.
In regards to programming: I won't be doing any large compilation or working on any large projects any time soon.
I heard about the Intel recalls, but I can't wait until late March / April.
Thanks.
Yeah, I only need 1TB for now, and I don't need a blue ray drive.
Since I will be ordering tomorrow, I can take further suggestions (if anybody has any).
No problem, let us know how it turns out, always like seeing a build regardless of if it's stock or modded.
Some changes that I would do to Outmyhead's build:
- Ditch the Core i7 870 and go with the Core i5 760:
$210 - Intel Core i5 760 CPU
The performance difference between the two in games does not justify the extra $80 for the i7 870.
- You can get this equal quality, if not better, and larger PSU for $4 less than the 650TX:
$100 - Antec Truepower New TP-750 750W PSU
- At $260, that GTX 470 card is simply overpriced. I recommend these cards instead:
$220 - Sapphire 100314-2SR Radeon HD 6870 1GB PCI-E Video Card
$253 - PowerColor AX6950 1GBD5-2DH Radeon HD 6950 1GB PCI-E Video Card
- This HSF has a better bang for the buck value than the Frio:
$30 - Cooler Master Hyper 212 Plus HSF for LGA 1366 and LGA 1156
- Case wise, the Corsair 600T is an excellent case. However there are other case options:
$80 - Lian Li Lancool PC-K58 ATX Case
$90 - NZXT Tempest Evo TEVO-001BK ATX Case
$90 - Lian Li Lancool PC-K56 ATX Case
$90 - Cooler Master CM690 II Advance ATX Case
$90 - Cooler Master HAF 922 RC-922M-KKN1-GP ATX Case
$100 - Lian Li PC-60FN ATX Case
$100 - Lian Li Lancool PC-K7B ATX Case
$110 - Lian Li PC-7B Plus II ATX Case
$110 - NZXT Whisper WHI - 001BK ATX Full Tower Case
$120 - Velocity Micro GX2-W Silver Classic Aluminum Case with Side Window
$140 - NZXT Phantom PHAN-001WT White Full Tower ATX Case
$140 - NZXT Phantom PHAN-001BK Black Full Tower ATX Case
$140 - Cooler Master HAF 932 RC-932-KKN1-GP ATX Case
$160 - Fractal Design Define R3 Black ATX Case (US Shipping Factored in) (Fill in the ++++ with "N C I X" without the spaces)
$160 - Fractal Design Define R3 Titanium ATX Case (US Shipping Factored in) (Fill in the ++++ with "N C I X" without the spaces)
$160 - Fractal Design Define R3 Silver ATX Case (US Shipping Factored in) (Fill in the ++++ with "N C I X" without the spaces)
$160 - Corsair Graphite Series 600T ATX Case
$160 - Silverstone RV02B-W ATX case
Wow didn't know that ordering from the north would be cheaper, my lack of knowledge from moving to the US from the UK.
That gave me an eye opener, maybe it will help copo too.
I'm going to add that site to my fav list to get some comparisons in future.
Glad you liked my choice of case, going off of Thermaltake lately, my sisters comp from Christmas was the last one I used, now leaning towards Corsair, and the Fractal cases.
