makavelli302
- May 1, 2011
1. What will you be doing with this PC? Gaming, Id like to run counter-strike source on the highest resolution / gfx settings getting above 200fps on average. Also would like to run COD and BF3 once released
2. What's your budget? 600-700 (already have a hard drive)
3. Where do you live? Id like to order all parts from newegg
4. What exact parts do you need for that budget? Id like an I5 / I7, 4 6 gigs of ram, defiantly would like to use an ITX mobo. The silverstonr sugo series s605bb with 450 watt psu looks like a great deal on newegg. Would like GFX card to support blueray movie / hdmi output / mini hdmi output.
5. If reusing any parts, what parts will you be reusing? Online run Nvidia gfx cards due some issues in certain maps with lighting.
6. What specific features do you need in a motherboard? Dont need anything special in regards to raid, firewire, or sli. 3.0 usb would be nice.
7. What resolution output do you need? 1080p (I do not need a monitor)
8. Does this system need to fit into a particular space? The case must be able to be brought onto a plane as my carry on. It will also be hooked up to my big screen as a median center when Im not on the road
9. How comfortable are you with custom case design/modification and electrical wiring? I can do small modifications internally to cases if necessary. I would like to put a after market air cooler on my system.
10. How important is the noise/silence of this sytem? Noise level is not a problem
11. How mobile does this system need to be? Very
12. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? I have windows 7 32 bit
13. When do you plan on building/buying the PC? Within the next couple weeks
