Need help building a budget gaming rig
deLuxe.EPiDEMiC
1)What will you be doing with this PC? Gaming? Photoshop? Web browsing? Etc
Just play some games like Dota 2 when that comes out. Video editing, recording, and rendering also.
Preferably 600 but I can go a little bit more if it's worth it.
3) Where do you live?
Southern California.
I’m building this from scratch so basically need everything but the OS. Thinking about a quad core will be fine.
None!
6) Will you be overclocking?
Nope!
No idea I think most likely a 20 inch one, but which one should I get?
As soon as possible!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Don’t really care about these.
Yes, 64 bit windows 7.
Thanks!
So you need a monitor as part of that $600 budget? Question 4, 5, and 7 don't match up.
looks like he's wanting to buy (planning to have) a 20" monitor as part of that budget, at least that's what it looks like he meant by that answer to question 7
Please try to be a little more specific OP.
Its hard to give good advice without the right information.
I'm looking to buy a 20inch but needed recommendations. The budget is only the rig, don't factor in the monitor, keyboard, mouse separately in the 600 budget.
Sorry for that!
Keeping in line with your updated budget (said via PMs):
$210 - Intel Core i5-2500 CPU
$120 - Asus P8H67-M PRO/CSM Intel H67 mATX Motherboard
$40 - Patriot Signature PSD34G13332 4GB DDR3 1333 RAM
$175 - Sapphire Radeon 100315L Radeon HD 6850 1GB PCI-E Video Card
$60 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$22 - Liteon 24X DVD Burner
$65 - Antec Earthwatts 650W PSU
$90 - Cooler Master CM690 II Advance ATX Case
Total: $782 shipped.
I went with Amazon.com since Amazon does not charge tax to CA residents
Thanks.
Btw, do you have any recommendations of a 20inch monitor or should I go higher? And only 4gig of ram is good enough?
Will be probably buying all of this tomorrow in the morning.
Thanks.
4GB of RAM is enough. Don't got a recommendation for a monitor now.
heres a nice monitor,
ASUS VE205T 20-Inch Widescreen LCD $117
and a dual channel ram kit
Corsair TW3X4G1333C9 XMS3 4GB 2 X 2 GB PC3-10666 1333Mhz $44.99
I tried an amd build but with a new am3+ socket coming by summer I cannot recommend going that way. Nice Intel build Danny_Bui
Could you talk a bit more about why you wouldn't go the AMD way?
I'm working on an AMD build right now in round about the same budget. (Just that I need a couple of fewer components.)
I would not spend more than about $150 maximum for an AMD CPU these days, especially since current AMD motherboards will not support the forthcoming Bulldozer CPUs at all.
Hey Danny, the price of the PSU went up. Do I still get it? Also I was thinking of getting a 23 inch instead of 20 the setup should be able to handle it easy too right?
No. Not worth it at $84. Pick up the Corsair 650TX instead:
$90 - Corsair 650TX 650W PSU
The CPU and RAM will be enough. The GPU might not be enough depending on how high the settings you want and what games you're planning on playing.
Hm, did you mean the radeon 6870 I found that priced at 240 on amazon but there was a GTX 470 also which leaded up me googling the 6870vs 470 discussions. In my case which one would be better o.0.
The 6870. The only reason to get the GTX 470 is if you are running (or planning to run) Adobe CS5 applications or if you are running or planning to run Linux.
Yeah I meant the HD 6870.
Just ordered everything, went with 6850 instead of 6870 because I couldn't spend 60 bucks just for stronger graphic card. Besides I do not plan on playing any high end games any time soon.
Had to order the case off NewEgg since it would come in 2-3 weeks after the other parts.
Btw, everything that was listed for me to buy is all I need right?Just plug them together install OS and play? No CPU heatsink, etc? Or do I need to buy them also o_O.
yup you should be go to go. Make sure there is thermal paste on teh cpu cooler before you install it. I cant imagine intel not shipping a cpu cooler without it but check to be safe.
The CPU comes with a HSF. You should be fine with that setup.
Welp got everything put together installed OS and the drivers but on the top of the case LED its red is that normal?
If you got the Cooler Master CM 690 II Advanced case, the LEDs on top of that case are red. The left LED (HDD LED) lights up only if something is accessing an internal drive connected to a SATA port. The right LED (Power LED) stays on as long as the system is powered on.
As for the blue front case LEDs around the fan, they're turned off by default. You'll need to press down on the leftmost button (left of the top eSATA port) on top of the case until it clicks to turn on the fan's LEDs.
